  2. Today
  3. 55trucker
    Rust free rotors?
  4. rich_e777
    Rust free rotors?
  5. Yesterday
  6. Black92GS
    Rust free rotors?
  7. GnatGoSplat
    Should I go back to stock?
  8. 55trucker
    Rust free rotors?
  9. Black92GS
    Rust free rotors?
  10. rich_e777
  11. Looking to replace the brake rotors on my 1994 Cutlass and I would like to have some that didnt form rust in the non-contact parts. Has anyone used some of the premium coated rotors offered with any success?
  12. Last week
  13. 94 olds vert
  14. Check Amazon. Just search Buick logo door light. Some are stick on with double sided tape and a magnet style sensor to activate them one the door opens.
  15. Usually Indian for some reason. i did get on rock auto for your application, they did have one of the mounts in GM.
  16. I guess I'll give DEA a try... from what I been reading it's all the same Subpar quality Chinese stuff.
  17. GM if you can get them, anchor would be last resort. I just ordered a complete set of DEA mounts a couple days ago ago for my Lumina.
  18. Greetings everyone. I tried searching but didnt find anything about what engine/trans mounts to go with. I know the options are very limited Anchor, Westar and DEA but I'm hoping yall can recommend which one you all have had the better experience. The car is a 2000 Buick regal GS thanks.
  19. Psych0matt
    TOM ( SUPERBUICK)
  20. Psych0matt
  21. Hey Guys, I'm restoring my 1993 Olds Convertible. I'm having trouble sourcing new rubber for the seals on the windows, doors, and trunk. Any ideas? Thanks!
  22. GnatGoSplat
    TOM ( SUPERBUICK)
    Wow, that's awesome!
  23. architect
    Draining Gas Tank - 95 Regal
  24. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  25. Amanita
    TOM ( SUPERBUICK)
    Damn, that's a rare one!
  26. SuperBuick
    TOM ( SUPERBUICK)
  27. SuperBuick
    Welcome!
  28. Earlier
  29. jmjp5055
    1972 cutlass Convertible
  30. GnatGoSplat
