92 Oldsmobile cutlass supreme A/C evaporator replacement
White93z34 replied to Ian's topic in General
wow! that thing was packed full of junk no wonder. -
Thanks for posting an update! Now I know why newer cars have a cabin air filter! I wonder how bad mine is. -
GnatGoSplat reacted to a post in a topic: 92 Oldsmobile cutlass supreme A/C evaporator replacement
Thanks for the options but did not need it. since I have a recovery machine with R134a it was not a big deal to open the system and refill it. Yes it was previously converted. after recovering the system I removed the one bolt under the hood holding the lines to the evaporator. Also I removed the clamps for the heater hoses at the firewall. Making sure a pan is under where you remove the heater hoses so not to spill it on the ground. under the dash at the floor I removed both left and right kick panels and gave access to where the bottom of the heater box is. I removed the silver trim around the cluster and radio, unbolted the center stack with that vent, climate control, and pocket. Behind that is another carpeted pocket unbolted that which gave me access to the heater box.. Removed the first panel that direct the floor air flow. There seems to be some pipe that goes into the floor under the carpet no idea where it goes since the back doesn’t have air vents or under the seats lol removing that panel I can see the heater core two or 7 mm. This car seems to be made with 7 mm screw screws.LOL . I was able to pull the heater core to the left and that gave me access to the evaporator. Remove the two screws on the bottom and I was able to pull the evaporator into the car and let me tell you I’ve attached a picture of what it looks like before cleaning it and after cleaning it after reinstalling everything and putting a new O-ring on the AC lines, putting a vacuum on the system and allowing my machine to refill the system with the correct amountthe airflow out of my vents was like a new car and my AC finally blows ice cold. All in all I was only left with 27 mm screws. I have no idea where they’re from but everything is nice and tight and working great. Now I know this isn’t a tutorial with instructions step-by-step but this is just what I had to go through since I couldn’t find any information and didn’t wanna wait for my service manual to come in which yes I did order on eBay. i’ve attached a few pictures before and after. I did do a little bit more cleaning after the clean picture I’ve attached. It looks like a brand new unit now. I hope in the future if somebody has to go through this and doesn’t understand what I’ve typed then can always reach out to me with questions.
pwmin reacted to a post in a topic: TGP hood vent repair.
94 olds vert reacted to a post in a topic: TGP hood vent repair.
Nice, thanks for that!
mdpierce8 started following 91 Grand Prix window motors
GnatGoSplat started following 91 Grand Prix window motors and cutlass wheel fitment
18x8 +42 with 5mm spacer = +37. Needed spacers to clear the front calipers, and I didn't want the rear to look more tucked than the front, so I put spacers on the rear just to match. Your tires would stick out 7mm more than mine if you go for 245-wide. -
Discoloration never even occurred to me. I don't think it's discoloring in the Cutlass yet. Yeah, I strongly suspect heat also plays a big part. It's been garaged over 24-years, thought it did spend ~10 hours a day during the Spring/Summer/Fall out in full sun for 19 of those years. It was 100% outdoors for 8+ years before that. I don't know if that's enough cumulative UV to cause this kind of vinyl decomposition. My garage does get really hot in the summer though. About 10-degrees over ambient, 15-20 if I've driven any of the cars, as the hot engine makes the garage even hotter. I've seen rubber belts in VCRs and cassette decks literally turn to black goo when stored in a hot garage, and that kind of equipment almost never sees sunlight. Seriously thinking maybe I need to install a mini split in my garage. -
Thank you!
