  2. pwmin
    91 Grand Prix window motors
    Nice, thanks for that!
  3. Today
  4. mdpierce8
  5. GnatGoSplat
    cutlass wheel fitment
    18x8 +42 with 5mm spacer = +37. Needed spacers to clear the front calipers, and I didn't want the rear to look more tucked than the front, so I put spacers on the rear just to match. Your tires would stick out 7mm more than mine if you go for 245-wide.
  6. GnatGoSplat
  7. Discoloration never even occurred to me. I don't think it's discoloring in the Cutlass yet. Yeah, I strongly suspect heat also plays a big part. It's been garaged over 24-years, thought it did spend ~10 hours a day during the Spring/Summer/Fall out in full sun for 19 of those years. It was 100% outdoors for 8+ years before that. I don't know if that's enough cumulative UV to cause this kind of vinyl decomposition. My garage does get really hot in the summer though. About 10-degrees over ambient, 15-20 if I've driven any of the cars, as the hot engine makes the garage even hotter. I've seen rubber belts in VCRs and cassette decks literally turn to black goo when stored in a hot garage, and that kind of equipment almost never sees sunlight. Seriously thinking maybe I need to install a mini split in my garage.
  8. Yesterday
  9. 94 olds vert
    New to me 93
  10. White93z34
    New to me 93
  11. jiggity76
    New to me 93
  12. rich_e777
    New to me 93
  13. mdpierce8
  14. 95cutlass
    New to me 93
    Thank you!
  15. 95cutlass
    New to me 93
  16. Last week
  17. 55trucker
    Cooling fan questions
  18. Megavolt-380
  19. 55trucker
  20. Megavolt-380
  21. jiggity76
  22. pwmin
  23. jiggity76
    New to me 93
  24. anyone on here that owns a cutlass with aftermarket wheels could you post a picture under this post of your ride, with wheel fitment specs. thanks to all i’m trying to figure out what type of wheels i want to put on and i was also wondering if a set of 18x8.5 +30 wheels would be too wide for the front or if the offset helps tuck enough
  25. I have the same thing happening on my Lincoln but not other cars. Its slowly turning the steering wheel and parts of the door cards a pinkish, lavender color from the light grey it should be too. I keep a reflector screen in the windshield so most of the interior stays in the shade. So I`m not 100% convinced its just the sun causing it. A similar thing is happening with a firebird where a black tar like substance is building up inside several electrical connectors in the engine bay like the big firewall C100.
  26. You could fill the the trunk up with bags of cement and deflate the back tires.
  27. rich_e777
    New to me 93
  28. jiggity76
  29. jmjp5055
    New to me 93
