So far, it rides better. I need stiffen them up a little because the tires scrub on bumps sometimes.
Brake upgrade completed
The Ford rotor *hat* is shorter, the overall height of the Ford rotor is only 1/4" more than that of the W rotor. The Impala rotors bolt circle is 118mm (4.6"), the W rotor is 115mm & the Ford is 114.5mm (4.5"). The Ford rotors pad surface thickness is near identical to the W rotor thickness 1.040" vs Ford 1.101". - Last week
HELP!!! Rear leaf spring bushing came out while driving
JOHN GTPPRIX replied to mycarsucks's topic in Brakes/Suspension/Steering/Wheels/Tires
I have for 24 years used the nylon pad/blocks and have had no problem. I bought and installed the rubber pads with the 3-M adhesive after cleaning them while a new rack unit was being installed. They didn't stay in place so I bought the nylon pads which lifted the car back up to a nice stance. I did grease the ends of the leaf spring. I have zero complaints and have had the car for 27 years. I replaced them once and I bought an extra pair and should install them again. -
Raffaelli replied to 55trucker's topic in Brakes/Suspension/Steering/Wheels/Tires
These are crown Vic 12 inch rotors? Curious why you didn’t use later w-body 12 inch front rotors, like an 05 impala? Seemed like it would work also… BTW -nice work! Custom stuff is always so cool. -
The fronts are not adjustable *out-of-the-box*, one has to use a dremel tool to open up (oval) the 3 front shock tower holes inwards to get a negative adjustment. At the rear one needs to (again) oval the thru holes at the bottom of the strut (inwards) to allow the knuckle to be moved *inwards* to get a more desirable negative setting. I'm sure that negative at both ends will change the cars handling characteristics to your liking. -
The last time I spun was when I was getting ready to go into a turn going 70+ and the back went out sending me sideways. I think what happened was at least one of the discs got really hot and made the braking force imbalanced since I wasn't attempting to turn at that point. Since then I've switched to a better brake fluid and put EBC Yellowstuff pads on the front of the car which I think are the most performance oriented compound you can get for the first gen Ws at this point, I tried getting rear pads as well but they are just not readily available. Haven't tracked it since doing this, but I'd like to get it back out there within the next year. I didn't know that about the alignment. The next time I'm getting ready to track it I'll take it to an alignment shop and have that done, Thanks for the advice! -
91lumina5.3 joined the community -
Given what you're doing with the car going bigger can't hurt, when you say you've spun out the car because of the brakes is that because the tail is loose & breaks free in a corner under braking? Being an FWD car the tail is more likely to follow the front where the front goes as the the back end is not driving the car. Something else to consider is the factory camber the cars alignment is set to, it's not slalom considered at all, the fronts are set to a .8 positive camber setting while the rears are at just on the + side of 0. If you were to go to a negative setting on both the front & rear I'm sure you see a far more responsive & more neutral response. -
I'm curious how well this does, I know my usecase isn't at all what these cars were designed for but on track the weakest link for these cars are the stock brakes. I have a '96 and even with the larger rotors they get really hot, I'm using pretty aggressive pads and they get toasty really easily, I've spun the car and gone off track because of it. I always just assumed that the next step would be to figure out how to fit larger calipers on the front and rear that can also take better pads. -
55trucker started following What's the reset process for a new accelerator pedal on an '08 3.8L? and Brake upgrade completed
Well, I completed my front brake upgrade, gone are the 10 1/2" rotors & in their retired place are a pair of 12" rotors. My approach for this was to maintain the original W calipers & just install larger dia rotors in the same manner that GM did when replacing the 10 1/2" rotors with 11 1/4" rotors. The W calipers are more than adequate on their own merits. The 11 1/4" calipers are pushed further out from center by a later design in the caliper bracket adapter. Seeing as I didn't want to purchase & then alter the 95-96 adapters I reconfigured what I had on the car. To do this alteration one has to remove the adapter that is welded to the steering knuckle. One has to cut away the outer section of the *ears* that the caliper bracket is bolted to. I sourced a length of 1/4"x2"x 12" A36 hot rolled mild steel flatbar, this bar is already stronger than the stamping of the adapters & the flatbar is thicker than the adapter by .050 thou. Starting with the drivers side which being done 1st served as the guinea pig for any mistakes I know I would make. I cut off the adapter, gave it a blasting, laid it out on a workbench & proceeded to mock up what the new longer *ears* would look like to get what was needed. Out of the 12" of flatbar I cut 4 *ears* each the same size, from there I laid out on each one the location where I would need to drill the 9/16 hole for the thru bolt. The *ears* have to be shaped into a circular manner on their edge so as to fit into the valley on the backside of the caliper brackets & be able for me to pivot them to get the appropriate angle before tacking them to the adapter. This mod requires that the new *ears* be overlaid onto the backside surface of the adapter. The new rotors *hat* is 1/4" deeper than the original rotor so the need for 1/4" flatbar to move the caliper back inward to get the proper location for the new rotors. Now the adapter has to be fastened back into place on the knuckle behind the hub assembly, install the new rotor onto the hub & lock it into place with a couple of wheel nuts, bolting loosely the *ears* to the cast caliper bracket I can now place the bracket over the rotor to get an approx location where the position will be that is the same as the original caliper was placed. I now install the caliper & the new pads into the bracket & slide the entire assembly over the new rotor, getting an accurate height position for the caliper on the rotor I now need to check that all of the caliper pad is contacting the rotor face. Seeing as the 12" rotor has a larger diameter one needs to make sure that the outer edge of the rotor will clear the inside edge of the stationary bracket but get all of the caliper pad on the rotor surface. I had to remove the brackets & mount them into a bench vise an carefully remove approx .030 tho of surface inside the very upper edge of the upper & very bottom edge of the lower portion to expand the radius to get the needed rotor clearance as it spins inside the stationary bracket. After doing this I can now reinstall the assembly, position the assembled caliper & bracket, position the new *ears* over the cut off ends of the adapter, tighten down the bolts to hold the *ears* where I want them & now tack the upper & lower *ear* into position. I repeated this same procedure for the right side but it went much faster seeing that after completing the left side I now have a template use for the right side. The welding was simple, remove everything from the car, bolt the cast caliper bracket to the adapter to prevent the adapter from warping while welding, mount them into a vise and run the beads, a flat downhand is best for this, the 71M wire puts down a nice wide bead to get maximum coverage for strength in a single pass. This welding procedure requires a minimum of a 200 amp mig, the wire I used was a deep penetration fabrication flux core wire for argon/c02 for heavy fab work such as construction/ship building. A 70S is not recommended. After getting everything assembled back together the last thin to cover is the new rotors hub opening, the W hubs are 70mm dia, the new rotors are 71 mm opening, this means that a 1mm shim is required to slide into the center of the rotor to properly center it over the hub. This was relatively easy, I pick up some 1mm stainless sheet steel & cut two shims 1/4" wide & to length & slipped them into the center of the rotor around the hub stub, then slide the rotor onto the hub. Worked perfect. It's been 2 weeks now since completion, after bedding in the new pads I have done some mild to moderate brake stops, working up to a few panic stops. The difference is instantly noticeable. The car just hauls down to a stop in a much quicker, shorter amount of time. Now since a few years ago when I did the booster upgrade the pedal feel at that time was instantly changed. Going from a hard, less than desirable *no assist* feel to a one can literally stop the car by using ones hand on the brake pedal, the booster supplies so much assist the pedal is like a feather to press. The pads because of their shape do not cover the entire rotor contact face, approx 70% of the rotor surface is made use of & that's the outer portion of the rotor. I have to believe that the smaller 11 1/4" rotors see this as well, not having had any in my hands to compare the contact area with the 10 1/2" rotors I'm pretty sure that THOSE rotors may have a larger dia hat area that reduces the contact area to something similar to the 10 1/2" rotors, these Ford Crown Vic rotors have a *hat* area that is the same as the 10 1/2" rotor hat. All in all...well worth my time & effort & what did it cost me? ...the price of a pair of new rotors & pads & a length of flatbar.
ernie22lord joined the community -
ceramicheper joined the community -
Cnuts24 joined the community -
cold joined the community -
Ok, yes, it does still function without it. I installed the new shift interlock solenoid, and it worked great. Too great. When i tried running the shifter through the gears, it worked fine. Until I tried to pull the key out of the ignition. It was stuck like glue. I tried every trick I knew and a few other people knew. Key wiggling, shifter pushing, steering wheel cranking to the far sides, disconnecting the battery, pushing on the interlock cable, pulling on the interlock cable, and a few more I can't remember right now. After leaving the car in the parking lot with its key in it last night (hung a roll of black gorilla tape over the key. It wouldn't go anywhere if they did get in and start it, anyway). Today I pulled the dash apart to try to get to the ignition switch so I could pull the tumbler cylinder out and work on it that way. As I was triggering the cable, I watched it as i pulled the shifter trigger button that releases the shift interlock solenoid. I reached down and grabbed the dead end of the cable on the back of the rocker that pulls it, I found that there was enough slack in the cable that i could pull it another 3/32" more cable past the point of where the rocker pulled it to. I tried pulling the key out and it came out! Apparently, the cable/wirehas stretched. I tried to figure out a way to crimp something on or adjust the rocker that pulls the cable, thinking maybe a lead fishing sinker crimped on there may work. But then I thought about the grandkids having it come uncrimped or slide up and going back to square one, so I disconnected the ignition switch end of the cable from its housing and it worked. I then thought, well, if that works, I wonder if it even needs the solenoid on there, so I tried it with the solenoid off. Still works. I checked for dash warning lights, went through the gears and it still functions fine. So the $80 solenoid is going back for a refund. I was a little worried about the car starting in gear, but it won't. It will start in park and neutral, but not in any of the driving gears, including reverse. I'm going to get them a new cable and install it sometime, but for now, it's fixed. Sort of. At least I don't have to buy a $200 ignition tumbler and have it recoded. Now, I just have to figure out what's wrong with the tranny. The shift cable is good and is switching through all the positions at the arm on top of the transmission, but it's not engaging in any gears and neutral isn't letting me role any. But at least the key isn't stuck anymore and I think I've fixed the problem with the shifter. Onward, to the next problem!
