Fuel Pump Replacement
ctaco started following Fuel Pump Replacement
55trucker started following Coilover Spring Rates , 3100 EGR delete without check engine light. and Drain tubes for convertible....
GnatGoSplat replied to cdn_olds_94's topic in Cutlass Supreme Convertible
Probably need to reseal your back window (windshield urethane is what I used). Mine had no drain and used to collect water, but I resealed my back window and it never collected water ever again. -
Toohfu joined the community -
GnatGoSplat started following Fuel Pump Replacement -
Getting a pry bar on the studs is next to impossible, given the space you're working with. The service manual for the car calls for a specialty tool literally no one sells. You have to make it yourself. Hope you know how to weld. And grooves to lock it in place? Bolts not work for the engineer? Did narrow wrenches and short sockets not exist in the 90's? The idiocracy of the design choices in the W-Body is astounding! Honda out there making cheap, easy to work on commuters in the 90's while GM was living in their own little city of dreams. Hollow, dim-headed loonies, the lot of them were.
