  2. Last week
  3. Go4DaMo
    Wheel fit
  4. I knew the make/model, not specific years. the bell housing is different. Google's gay robot doesn't know about the TC. It also thinks it was in a 94 Lumina. Like hell it was.
  5. 55trucker
    Wheel fit
  6. Psych0matt
    New to this place. Hello.
  7. rich_e777
    Wheel fit
  8. Earlier
  9. 94 olds vert
  10. 55trucker
  11. 94 olds vert
  12. Hi, I have a 92 Chevy Lumina Z34 automatic with the V6 DOHC. It's all stock. I am new to fixing cars and got it a year ago. Any tips or suggestions is appreciated. The current thing I'm working on it wiring and brakes.
  13. RPE1992GPSE
    Should I go back to stock?
  14. There's a guy in Denver that we used to use a lot that checked mine out that might be worth talking to: Steve's Transmissions and Gears 303-744-7904
  15. carkhz316
  16. 55trucker
    Wheel fit
  17. rich_e777
    Wheel fit
  18. Psych0matt
    Wheel fit
  19. It shouldn't be much lower than it was, but I definitely should get it aligned again. It's hard to tell since I had them all the way apart. I should have measured the wheel gap and/or fender height from the ground before and after, but I didn't for some reason.
  20. pwmin
    Wheel fit
  21. I'm seeing -.65 on both front wheels as the finished setting by the shop, that's a little more than negative half a degree. You're at just under 1 degree negative on the rears. I personally wouldn't adjust those at all, but those settings were done 2 years ago, you've had the front end apart & the car now sits lower, that will alter those earlier settings to some degree. Lowering the car will induce more negative camber.
  22. I'm at just under - 1. I raised it a little more.
  23. Go4DaMo
    Wheel fit
  24. Go4DaMo
    Luminac
    Unsubscribe
  25. Go4DaMo
    1st Gen W body 14" wheels?
  26. I do, so I'll have to check later and reference my alignment printout.
  27. I don't have a 2nd gen GM service manual so I do not know what the factory set the camber to.
  28. I can't recall, but it's close to stock. I think I should probably be able to go more negative without issue.
