JulienStocola joined the community
There was a time when the rubber pads and SPECIAL glue were available in the aftermarket--Dorman 31066. Maybe it's still available--somewhere. https://www.amazon.com/Dorman-31066-Leaf-Spring-Insulator/dp/B000COCRB4 The way I remember it, the glue was a real pain in the azz, couldn't get frozen, had a short shelf-life, etc. Depending on who you talk to, the rubber pads are--or are not--used with the hard, nylon blocks sold by Moog and others. - Earlier
X -
Describe the *noise* you are hearing.......you say that this was heard when the original spring was still in place? Does the *replacement* spring still have the rubber pads glued to the ends of the leaf?
