There was a time when the rubber pads and SPECIAL glue were available in the aftermarket--Dorman 31066. Maybe it's still available--somewhere. https://www.amazon.com/Dorman-31066-Leaf-Spring-Insulator/dp/B000COCRB4 The way I remember it, the glue was a real pain in the azz, couldn't get frozen, had a short shelf-life, etc. Depending on who you talk to, the rubber pads are--or are not--used with the hard, nylon blocks sold by Moog and others. - Yesterday
GnatGoSplat started following '92 GTP, Why is it making this noise? , 1993 Cutlass convertible top not moving, down or up , Convertible top relays location 1995 and 1 other
X -
