  2. jiggity76
    New to me 93
    Interesting. I think it's an early W body thing and dependent on whether it's a sedan, coupe, or convertible, (Cutlass line of course). I think the newer cars maybe starting in 94 on...again, depending on body style, they just got a combination of those items.
  3. Today
  4. rich_e777
    New to me 93
  5. mdpierce8
    91 Grand Prix window motors
  6. 95cutlass
    New to me 93
    Thank you!
  7. 95cutlass
    New to me 93
  8. Yesterday
  9. 55trucker
    Cooling fan questions
  10. Megavolt-380
  11. 55trucker
  12. Megavolt-380
  13. jiggity76
  14. pwmin
  15. jiggity76
    New to me 93
  16. anyone on here that owns a cutlass with aftermarket wheels could you post a picture under this post of your ride, with wheel fitment specs. thanks to all i’m trying to figure out what type of wheels i want to put on and i was also wondering if a set of 18x8.5 +30 wheels would be too wide for the front or if the offset helps tuck enough
  17. I have the same thing happening on my Lincoln but not other cars. Its slowly turning the steering wheel and parts of the door cards a pinkish, lavender color from the light grey it should be too. I keep a reflector screen in the windshield so most of the interior stays in the shade. So I`m not 100% convinced its just the sun causing it. A similar thing is happening with a firebird where a black tar like substance is building up inside several electrical connectors in the engine bay like the big firewall C100.
  18. You could fill the the trunk up with bags of cement and deflate the back tires.
  19. rich_e777
    New to me 93
  20. jiggity76
  21. jmjp5055
    New to me 93
  22. mdpierce8
  23. 55trucker
  24. White93z34
  25. 55trucker
  26. Last week
  27. White93z34
  28. Megavolt-380
  29. 55trucker
