chris mangione joined the community - Yesterday
GnatGoSplat started following GM part number for Eaton supercharger on Series I 3800 v6 and 1992 Cutlass Supreme Coupe Door Speakers
GnatGoSplat replied to Northstarlc3's topic in Powertrain
91-93 88984224 94-95 12480745 Hope that helps.
