  2. Yesterday
  3. carkhz316
    LS4 swap begins
  4. 94 olds vert
    Muffler options
  5. Last week
  6. Jscott
    Muffler options
  7. carkhz316
    Thanks for this.
  8. Earlier
  9. Go4DaMo
    Wheel fit
  10. I knew the make/model, not specific years. the bell housing is different. Google's gay robot doesn't know about the TC. It also thinks it was in a 94 Lumina. Like hell it was.
  11. 55trucker
    Wheel fit
  12. Psych0matt
    New to this place. Hello.
  13. rich_e777
    Wheel fit
  14. 94 olds vert
  15. 55trucker
  16. 94 olds vert
  17. Hi, I have a 92 Chevy Lumina Z34 automatic with the V6 DOHC. It's all stock. I am new to fixing cars and got it a year ago. Any tips or suggestions is appreciated. The current thing I'm working on it wiring and brakes.
  18. RPE1992GPSE
    Should I go back to stock?
  19. There's a guy in Denver that we used to use a lot that checked mine out that might be worth talking to: Steve's Transmissions and Gears 303-744-7904
  20. carkhz316
  21. 55trucker
    Wheel fit
  22. rich_e777
    Wheel fit
  23. Psych0matt
    Wheel fit
  24. It shouldn't be much lower than it was, but I definitely should get it aligned again. It's hard to tell since I had them all the way apart. I should have measured the wheel gap and/or fender height from the ground before and after, but I didn't for some reason.
  25. pwmin
    Wheel fit
  26. I'm seeing -.65 on both front wheels as the finished setting by the shop, that's a little more than negative half a degree. You're at just under 1 degree negative on the rears. I personally wouldn't adjust those at all, but those settings were done 2 years ago, you've had the front end apart & the car now sits lower, that will alter those earlier settings to some degree. Lowering the car will induce more negative camber.
  27. I'm at just under - 1. I raised it a little more.
  28. Go4DaMo
    Wheel fit
  29. Go4DaMo
    Luminac
    Unsubscribe
