Psych0matt reacted to a post in a topic: 92 (88-94?) sunroof relay
JulienStocola joined the community
Apparently It’s called a spring plate. If I’m seeing things correctly, it seems like it’s used to attach to lower part of a spring compressor. - Earlier
X -
