Got the fuel line disconnected and fuel can ready to go but no go on the fuel pump. Do I have it wrong here? The car has been sitting for 6 weeks so the battery may be weak but radio turns on. Edit nevermind I'm an idiot i see the number on bottom of relay and i had it wrong
OIL LEAK - 1994 Cutlass LQ1
Damn, that's a rare one!
Welcome! -
chris mangione joined the community - Earlier
