rich_e777 reacted to a post in a topic: Help fix top motor
Psych0matt reacted to a post in a topic: 92 (88-94?) sunroof relay
JulienStocola joined the community
X -
Describe the *noise* you are hearing.......you say that this was heard when the original spring was still in place? Does the *replacement* spring still have the rubber pads glued to the ends of the leaf?
