Go4DaMo reacted to a post in a topic: cutlass wheel fitment
jiggity76 reacted to a post in a topic: New to me 93
dropping the rear of cutlass
rich_e777 reacted to a post in a topic: New to me 93
jiggity76 reacted to a post in a topic: Cooling fan questions
about 12v and below
goldrush25 joined the community
what if i js took out the rear monoleaf and put some spacers would it work ? i mean the ride will obviously be bad but as long as it will actually drive like that i think i’d be fine with that -
Autopia.sa joined the community
White93z34 replied to 97cutty's topic in Brakes/Suspension/Steering/Wheels/Tires
Not really any of those as I recall. once upon a time someone made lowering leafs, pretty sure unless you find one of those your only option is DIY coil overs, Its been done here but honestly I was never into that so I can't speak to it
