GnatGoSplat started following 92 (88-94?) sunroof relay , 1993 Cutlass convertible top not moving, down or up , Radio replacement for a 1994 Cutlass Supreme Convertible and 1 other
Yep, I've probably removed the bezel a hundred times across 3 Cutlass Supremes and it's never broken. It's hard plastic and seems brittle, but it's actually quite durable. - Yesterday
Cojack87 joined the community
Jakey joined the community
JulienStocola joined the community
