  2. Raffaelli
    Fuel Pump Replacement
  3. ctaco
  4. ctaco
  5. 55trucker
  6. Raffaelli
  7. ctaco
  8. Yesterday
  9. GnatGoSplat
  10. GnatGoSplat
    Drain tubes for convertible....
    Probably need to reseal your back window (windshield urethane is what I used). Mine had no drain and used to collect water, but I resealed my back window and it never collected water ever again.
  11. Last week
  12. Topless1994
    I know this is an old thread but having the same problem. Can anyone help?
  13. bluecalais79
    A/C Repair - LQ-1
  14. Black92GS
  15. 32 Clicks of Rebound Force Adjustment (I'm assuming single)
  16. The softer the spring one uses the stiffer the dampening that's needed to keep ones ride from *floating*. Are these Rev9 shocks single or double acting?
  17. Well, crap, I'm an idiot Spring Rate(FRONT): 8 kg/mm (448 lbs/inch) (8k) (Spring Rate(REAR): 5 kg/mm (280 lbs/inch) (5k) https://www.ebay.com/itm/363295804829 BC (from ZZP): 5k Front, 6k Rear ZZP: 6.6kg front spring rate, 6.6kg rear spring rate Looks like I'm going to switch the fronts out for probably 6k if I can find them in 200mmx62mm (7.87" x 2.44") and try that. I believe the other ones use 10" springs, but I'll have to measure the other car this weekend.
  18. Hmmmmmm.......... the Rev9 supplier doesn't disclose the coil spring rates to the customer? is it safe to assume you're using the 97-04 Buick Regal coils? https://coiloverkits.com/collections/rev9-coilovers/products/buick-regal-coilovers-1997-2004-rev9-hyper-street-ii-32-way-adjustable
  19. I have Rev9 coilovers on my 2001 GT. I have 0 pre-load, which helps, but they're still a little bouncy and harsh no matter what I set the damper setting to. I have ZZP coilovers on the red car and, while not perfect, they are much better. I'm trying to figure out what spring rate they are or if anyone knows what I should swap them out for? I'm also going to grab more collars so I can lock them together. They keep coming loose. They have a thin lock washer, but one of them broke.
  20. White93z34
  21. Chapstick
  22. Earlier
  23. I think I watched a guy on YouTube do one, and he used a claw hammer.
  24. Getting a pry bar on the studs is next to impossible, given the space you're working with. The service manual for the car calls for a specialty tool literally no one sells. You have to make it yourself. Hope you know how to weld. And grooves to lock it in place? Bolts not work for the engineer? Did narrow wrenches and short sockets not exist in the 90's? The idiocracy of the design choices in the W-Body is astounding! Honda out there making cheap, easy to work on commuters in the 90's while GM was living in their own little city of dreams. Hollow, dim-headed loonies, the lot of them were.
  25. 94 olds vert
  26. Psych0matt
  27. pwmin
  28. White93z34
  29. The threads on the fitting for my EGR tube at the exhaust manifold no longer exist. The tube isn't available anywhere. Figured at this point I'd just delete the EGR. Are there any ways to trick the car into thinking there's still an EGR so I don't have annoying check engine light? 1994 Pontiac Grand Prix 3100
