  2. Usually Indian for some reason. i did get on rock auto for your application, they did have one of the mounts in GM.
  3. Today
  4. I guess I'll give DEA a try... from what I been reading it's all the same Subpar quality Chinese stuff.
  5. GM if you can get them, anchor would be last resort. I just ordered a complete set of DEA mounts a couple days ago ago for my Lumina.
  6. Greetings everyone. I tried searching but didnt find anything about what engine/trans mounts to go with. I know the options are very limited Anchor, Westar and DEA but I'm hoping yall can recommend which one you all have had the better experience. The car is a 2000 Buick regal GS thanks.
  7. Psych0matt
    TOM ( SUPERBUICK)
  8. Psych0matt
  9. Yesterday
  10. Hey Guys, I'm restoring my 1993 Olds Convertible. I'm having trouble sourcing new rubber for the seals on the windows, doors, and trunk. Any ideas? Thanks!
  11. GnatGoSplat
    TOM ( SUPERBUICK)
    Wow, that's awesome!
  12. Last week
  13. architect
    Draining Gas Tank - 95 Regal
  14. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  15. Amanita
    TOM ( SUPERBUICK)
    Damn, that's a rare one!
  16. SuperBuick
    TOM ( SUPERBUICK)
  17. SuperBuick
    Welcome!
  18. jmjp5055
    1972 cutlass Convertible
  19. Earlier
  20. GnatGoSplat
  21. Raffaelli
  22. bluecalais79
  23. 94 olds vert
  24. bluecalais79
  25. 55trucker
    Sunroof help again.
  26. Jscott
    Sunroof help again.
  27. bluecalais79
  28. GnatGoSplat
  29. 94 olds vert
    anyways, welcome to the site.
  30. Psych0matt
