  2. I have the same thing happening on my Lincoln but not other cars. Its slowly turning the steering wheel and parts of the door cards a pinkish, lavender color from the light grey it should be too. I keep a reflector screen in the windshield so most of the interior stays in the shade. So I`m not 100% convinced its just the sun causing it. A similar thing is happening with a firebird where a black tar like substance is building up inside several electrical connectors in the engine bay like the big firewall C100.
  3. Today
  4. You could fill the the trunk up with bags of cement and deflate the back tires.
  5. rich_e777
    New to me 93
  6. jiggity76
    91 Grand Prix window motors
  7. jmjp5055
    New to me 93
  8. mdpierce8
  9. 55trucker
    Cooling fan questions
  10. White93z34
  11. 55trucker
  12. Yesterday
  13. White93z34
  14. Megavolt-380
  15. 55trucker
  16. 55trucker
  17. Megavolt-380
    about 12v and below
  18. Megavolt-380
  19. Last week
  20. White93z34
  21. 55trucker
  22. 55trucker
  23. Megavolt-380
  24. Megavolt-380
  25. 95cutlass
    New to me 93
  26. what if i js took out the rear monoleaf and put some spacers would it work ? i mean the ride will obviously be bad but as long as it will actually drive like that i think i’d be fine with that
  27. Not really any of those as I recall. once upon a time someone made lowering leafs, pretty sure unless you find one of those your only option is DIY coil overs, Its been done here but honestly I was never into that so I can't speak to it
  28. jiggity76
  29. 55trucker
