  2. White93z34
    New to me 93
  3. Today
  4. jiggity76
    New to me 93
  5. rich_e777
    New to me 93
  6. mdpierce8
    91 Grand Prix window motors
  7. 95cutlass
    New to me 93
    Thank you!
  8. 95cutlass
    New to me 93
  9. Yesterday
  10. 55trucker
    Cooling fan questions
  11. Megavolt-380
  12. 55trucker
  13. Megavolt-380
  14. jiggity76
  15. pwmin
  16. jiggity76
    New to me 93
  17. anyone on here that owns a cutlass with aftermarket wheels could you post a picture under this post of your ride, with wheel fitment specs. thanks to all i’m trying to figure out what type of wheels i want to put on and i was also wondering if a set of 18x8.5 +30 wheels would be too wide for the front or if the offset helps tuck enough
  18. I have the same thing happening on my Lincoln but not other cars. Its slowly turning the steering wheel and parts of the door cards a pinkish, lavender color from the light grey it should be too. I keep a reflector screen in the windshield so most of the interior stays in the shade. So I`m not 100% convinced its just the sun causing it. A similar thing is happening with a firebird where a black tar like substance is building up inside several electrical connectors in the engine bay like the big firewall C100.
  19. You could fill the the trunk up with bags of cement and deflate the back tires.
  20. rich_e777
    New to me 93
  21. jiggity76
  22. jmjp5055
    New to me 93
  23. mdpierce8
  24. 55trucker
  25. White93z34
  26. 55trucker
  27. Last week
  28. White93z34
  29. Megavolt-380
