  2. jiggity76
    New to me 93
  3. anyone on here that owns a cutlass with aftermarket wheels could you post a picture under this post of your ride, with wheel fitment specs. thanks to all i’m trying to figure out what type of wheels i want to put on and i was also wondering if a set of 18x8.5 +30 wheels would be too wide for the front or if the offset helps tuck enough
  4. Today
  5. I have the same thing happening on my Lincoln but not other cars. Its slowly turning the steering wheel and parts of the door cards a pinkish, lavender color from the light grey it should be too. I keep a reflector screen in the windshield so most of the interior stays in the shade. So I`m not 100% convinced its just the sun causing it. A similar thing is happening with a firebird where a black tar like substance is building up inside several electrical connectors in the engine bay like the big firewall C100.
  6. You could fill the the trunk up with bags of cement and deflate the back tires.
  7. rich_e777
    New to me 93
  8. jiggity76
    91 Grand Prix window motors
  9. jmjp5055
    New to me 93
  10. mdpierce8
  11. 55trucker
    Cooling fan questions
  12. White93z34
  13. 55trucker
  14. Yesterday
  15. White93z34
  16. Megavolt-380
  17. 55trucker
  18. 55trucker
  19. Megavolt-380
    about 12v and below
  20. Megavolt-380
  21. Last week
  22. White93z34
  23. 55trucker
  24. 55trucker
  25. Megavolt-380
  26. Megavolt-380
  27. 95cutlass
    New to me 93
  28. what if i js took out the rear monoleaf and put some spacers would it work ? i mean the ride will obviously be bad but as long as it will actually drive like that i think i’d be fine with that
  29. Not really any of those as I recall. once upon a time someone made lowering leafs, pretty sure unless you find one of those your only option is DIY coil overs, Its been done here but honestly I was never into that so I can't speak to it
