pwmin reacted to a post in a topic: 5.3L LS4 swap into a 95 Oldsmobile Cutlass Supreme SL
55 linked some w-body specific links. You may also check into the Fiero groups and see how their wiring is done and which PCM's they use. If you're on Facebook go to this group https://www.facebook.com/share/g/16TmFr1XSe/ They specialize in Fiero's, but he's posted a ton of info on wiring and PCM's. the concept will be the same, even if the wiring plugs to match the rest of the car harness don't line up. - Today
so this is my first post here on this forum and i don't quite know what to get out of it, as you saw I'm attempting to get all pieces together to get a 5.3L LS4 swapped into my 95 Oldsmobile Cutlass Supreme SL. Being a obd 1 car i don't know if its only the ecm/ecu that runs the tranny or if there's a bcm ( body control module) that goes with it, that being said this car was given to me as a gift from my grandfather who recently passed, so if you guys are tryna convince me to start with something else forget it, ive seen the motor go into the car already and the guy who posted it here was even brave enough to get a 4t80 inside along with it. my main question is what ecu and standalone kit would be best used for this setup as i only see all other ecu's being compatible with the other LS engines instead of this one
90sEraWhips reacted to a post in a topic: Subframe Bushings?
GnatGoSplat started following 92 (88-94?) sunroof relay , 1993 Cutlass convertible top not moving, down or up , Radio replacement for a 1994 Cutlass Supreme Convertible and 1 other
Yep, I've probably removed the bezel a hundred times across 3 Cutlass Supremes and it's never broken. It's hard plastic and seems brittle, but it's actually quite durable. -
Cojack87 joined the community
Jakey joined the community
