  2. Does anyone know what is involved in removing the radio on this model? The trim is brittle and I don’t want to break anything that can’t be replaced. I removed the trim screws from under the top of the dash but I’m afraid to slide the trim out that goes around the radio and gauges.
  3. The blocks are without the rubber and just help in place by the spring tension. After liberal use of Lucas red and sticky on the blocks the noise has stopped. It has been about a week now so I'm hopeful this issue is solved. Thank you all for the reply and info
  4. Psych0matt
    92 (88-94?) sunroof relay
  5. GnatGoSplat
  6. Psych0matt
  7. GnatGoSplat
  8. Psych0matt
  9. Yesterday
  10. Loctite Hysol 11C glue is actually a really good 2-part epoxy. I use it to repair lots of things. I keep it inside, but the shelf life has been pretty good, lasting over 2-decades. Used it last December and it was still good. That Dorman kit worked pretty well for me, I think I repaired at least 2 W-bodies with it and never had a repeat repair. Shame it's not sold any more. It was supposed to be equivalent to OEM replacement ends and looked identical, so you didn't need the Moog blocks with them.
  11. GnatGoSplat
  12. Last week
  13. Psych0matt
  14. Psych0matt
  15. Psych0matt
  16. Ric
    Help fix top motor
  17. 55trucker
  18. Psych0matt
  19. Psych0matt
  20. I need several electrical connectors replaced on my 2.8. Can anyone tell me if they can help me out? I don’t think any of the connectors are going to work with my harness from a 3.1 because I have a vacuum egr valve. The 3.1 mostly has the electronic egr valve and I seen the connectors are completely the opposite. What about the other sensors? Can I crimp these connectors from the harness that has the electronic egr valve and crimp them onto my harness that has the vacuum egr? list of connectors that need to be replaced due to a critter chewing them. The bastard even chewed all of my weather packs smh. MAP SENSOR- GREEN WEATHERPACK - VAPOR CANISTER PURGE VALVE SOLENOID- TAN WEATHERPACK - EGR VALVE- GREY WEATHERPACK 2.8 only vacuum - CRANKSHAFT POSITION SENSOR- BLUE WEATHERPACK - THROTTLE POSITION SENSOR- BLUE WEATHERPACK - COOLANT ENGINE TEMP SENSOR- BLUE WEATHERPACK - IDLE AIR CONTROL VALVE- BLUE WEATHERPACK - OIL PRESSURE SENDER SWITCH- NEAR THE OIL FILTER- GREEN WEATHERPACK - AC COMPRESSOR CLUTCH COIL CONNECTOR- CONNECTOR IS ON THE SIDE OF THE CLUTCH PULLEY- BLUE WEATHERPACK - AIR INTAKE TEMP SENSOR- on the air filter box- BLUE WEATHERPACK
  21. 94 olds vert
  22. 55trucker
  23. Schurkey
  24. Earlier
  25. Psych0matt
  26. Psych0matt
  27. Psych0matt
  28. Psych0matt
  29. There was a time when the rubber pads and SPECIAL glue were available in the aftermarket--Dorman 31066. Maybe it's still available--somewhere. https://www.amazon.com/Dorman-31066-Leaf-Spring-Insulator/dp/B000COCRB4 The way I remember it, the glue was a real pain in the azz, couldn't get frozen, had a short shelf-life, etc. Depending on who you talk to, the rubber pads are--or are not--used with the hard, nylon blocks sold by Moog and others.
