  2. Jscott
  3. Yesterday
  4. 55trucker
  5. So I bought an old Matco 4000e scanner. Came with a pathfinder 2 cartridge and just a ford cable. I want to locate or make a harness for that to fit a GM obd1. The unit has a db25 male connection on it. But it also needs to be powered up too… any ideas would be a great help. Thanks.
  6. Last week
  7. Earlier
  8. sadolboy48
    89 olds swaybar
  9. 55trucker
    89 olds swaybar
  10. sadolboy48
    89 olds swaybar
  11. 55trucker
    89 olds swaybar
  12. sadolboy48
    89 olds swaybar
  13. Psych0matt
  14. rich_e777
    89 olds swaybar
  15. 94 olds vert
  16. 55trucker
    89 olds swaybar
  17. Runs rough. New coils plugs wires after hot.
  18. Raffaelli
    89 olds swaybar
  19. sadolboy48
    89 olds swaybar
  20. sadolboy48
    89 olds swaybar
  21. Bake82
    89 olds swaybar
  22. sadolboy48
    89 olds swaybar
  23. sadolboy48
    89 olds swaybar
  24. 94 olds vert
    89 olds swaybar
  25. I have an 89 oldsmobile cutlass supreme 3.1 my front swaybar broke on the passengers side, not inlinks, it doesn't have any, the whole bar broke. Been looking everywhere for some kind of replacement. Just wondering if anyone knows any kind of other car that I can use one from because I can't seem to find any. Never seen a whole sawybar break but sure didn't think that it would be so hard to find one. The ones I can find are either for earlier or later models that do have inlinks and they won't fit.
  26. Thanks! Looks like they both use the same fcs rear shock/strut assembly according to rockauto. I'll definitely keep in mind looking into springs as well.
  27. Another on-line resources for checking part compatibility is a recycling yard search engine site called car-part.com. The search results can be set to include "All Interchange Choices", so that the search results include vehicles with parts that fit your vehicle Or you could call a recycling yard and ask about interchange options.
  28. I personally cannot say, though my usual method is to go on Rockauto and look up both vehicles with a more common strut, KYB, Monroe whatever and see if the part numbers match, if those more common struts are the same I'd say theres a good chance the Bilstiens fit. You many want to change springs as well as I'd imagine Buick springs may be made for a different ride height and for sure will be softer.
  29. I'm looking at getting new rear shocks and struts for my 2007 Buick Lacrosse, and I noticed bilstein makes struts and shocks for the same gen Impala. I was wondering if anyone knows if they would bolt up without any modification. If not, does anyone have any recommendations on something specifically for the Lacrosse?
