  2. Today
  3. 55trucker
    Sunroof help again.
  4. Jscott
    Sunroof help again.
  5. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  6. Yesterday
  7. GnatGoSplat
  8. 94 olds vert
    anyways, welcome to the site.
  9. Psych0matt
  10. bluecalais79
  11. RPE1992GPSE
  12. Good day, I have been a W body enthusiast since high school 04. In my student parking lot, we had a 93 Gran prix, 94 olds cutlass supreme, 94 cavalier z24, 95 monte, and my lumina z34. These cars were everywhere! My first car was a 94 lumina z34 (still have it). In 2012 I put a 4.9 PFI in it and it is almost complete. I just need to replace the rear suspension and odds and ends. I have a 99 Monte (needs some work), and I just picked up a decent (needs some work) Cutlass supreme. I am buying a new top for the cutlass on Friday. I want to get black canvass instead of the white (the car has black leather interior). They come in black, grey, white, red. What do you all think would be the best color? Just curious. Very few of these ole buggies still around (at least in my area). I thought I would join the forum to see what you all are up to (I feel very late to the party). I already have seen some super nice examples of these cars (nice job everyone!). Ill post more as spring hits and I can get them out, and work on them more. Also, not adverse to loading them up on the trailer for any meets that might happen. Thank you! Hope you all have a wonderful day!
  13. Bake82
  14. White93z34
  15. GnatGoSplat
  16. bluecalais79
  17. Last week
  18. 55trucker
    1972 cutlass convertible
  19. I’m looking for the left driver side rear top rail. It connects to the left rear panel.. Need asap
  20. I’m looking for the left driver side rear top rail. It connects to the left rear panel.. Need asap
  21. GnatGoSplat
  22. GnatGoSplat
  23. RPE1992GPSE
  24. GnatGoSplat
  25. GnatGoSplat
    GM part number for Eaton supercharger on Series I 3800 v6
    91-93 88984224 94-95 12480745 Hope that helps.
  26. GnatGoSplat
    RPO code for 3.29 gear ratio in olds intrigue.
    FR9. Hope that helps.
  27. 55trucker
    Draining Gas Tank - 95 Regal
    There are various designs...plastic or steel.......seeing as you don't intend on getting into this sort of repair again I'd suggest just picking up the plastic set, you should be able to find them at Harbor Freight. The inlet (pressure side) is 3/8 as for a gas can..really up to you..pick up a pair of containers that will hold a total of 15 gals?
  28. architect
    Lifting the car isn't an option so I'll run out to gab the device. Thanks. Any idea what size clear tub would work? Don't have any spare garden hose to sacrifice.
  29. 55trucker
    This is the only device that will separate the fuel line from the rail.... there is another method you might try.... raise the car up high enough to get under comfortably & disconnect the fuel filter from the fuel line (one end of the filter makes used of threaded connection , the other end is the same ac/fuel line quick disconnect slip-on connection). Once again run a length of hose long enough to clear the car & fill a gas container to drain the tank.
