I think I used a 2x4 between the studs to twist it. - Last week
ctaco started following Fuel Pump Replacement
55trucker started following Coilover Spring Rates , 3100 EGR delete without check engine light. and Drain tubes for convertible....
GnatGoSplat replied to cdn_olds_94's topic in Cutlass Supreme Convertible
Probably need to reseal your back window (windshield urethane is what I used). Mine had no drain and used to collect water, but I resealed my back window and it never collected water ever again. -
I know this is an old thread but having the same problem. Can anyone help? - Earlier
GnatGoSplat started following Fuel Pump Replacement -
