  2. Greetings everyone. I tried searching but didnt find anything about what engine/trans mounts to go with. I know the options are very limited Anchor, Westar and DEA but I'm hoping yall can recommend which one you all have had the better experience. The car is a 2000 Buick regal GS thanks.
  3. Today
  4. Psych0matt
    TOM ( SUPERBUICK)
  5. Psych0matt
  6. Yesterday
  7. Hey Guys, I'm restoring my 1993 Olds Convertible. I'm having trouble sourcing new rubber for the seals on the windows, doors, and trunk. Any ideas? Thanks!
  8. GnatGoSplat
    TOM ( SUPERBUICK)
    Wow, that's awesome!
  9. Last week
  10. architect
    Draining Gas Tank - 95 Regal
  11. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  12. Amanita
    TOM ( SUPERBUICK)
    Damn, that's a rare one!
  13. SuperBuick
    TOM ( SUPERBUICK)
  14. SuperBuick
    Welcome!
  15. jmjp5055
    1972 cutlass Convertible
  16. Earlier
  17. GnatGoSplat
  18. Raffaelli
  19. bluecalais79
  20. 94 olds vert
  21. bluecalais79
  22. 55trucker
    Sunroof help again.
  23. Jscott
    Sunroof help again.
  24. bluecalais79
  25. GnatGoSplat
  26. 94 olds vert
    anyways, welcome to the site.
  27. Psych0matt
  28. bluecalais79
  29. RPE1992GPSE
  30. Good day, I have been a W body enthusiast since high school 04. In my student parking lot, we had a 93 Gran prix, 94 olds cutlass supreme, 94 cavalier z24, 95 monte, and my lumina z34. These cars were everywhere! My first car was a 94 lumina z34 (still have it). In 2012 I put a 4.9 PFI in it and it is almost complete. I just need to replace the rear suspension and odds and ends. I have a 99 Monte (needs some work), and I just picked up a decent (needs some work) Cutlass supreme. I am buying a new top for the cutlass on Friday. I want to get black canvass instead of the white (the car has black leather interior). They come in black, grey, white, red. What do you all think would be the best color? Just curious. Very few of these ole buggies still around (at least in my area). I thought I would join the forum to see what you all are up to (I feel very late to the party). I already have seen some super nice examples of these cars (nice job everyone!). Ill post more as spring hits and I can get them out, and work on them more. Also, not adverse to loading them up on the trailer for any meets that might happen. Thank you! Hope you all have a wonderful day!
