55trucker started following 1st Gen W body 14" wheels? , 3100 EGR delete without check engine light. , Drain tubes for convertible.... and 1 other
A/C Repair - LQ-1
GnatGoSplat replied to cdn_olds_94's topic in Cutlass Supreme Convertible
Probably need to reseal your back window (windshield urethane is what I used). Mine had no drain and used to collect water, but I resealed my back window and it never collected water ever again. - Yesterday
Toohfu joined the community -
AFM_Hater69 joined the community - Earlier
