  2. Can someone with a stock 1990 LH0 W-body tell me exactly which ADX/XDF/BIN combination they're using with TunerPro RT? Also does anyone know the factory procedure for setting the throttle stop screw on a 1990 LH0 throttle body? Mine was previously adjusted, and I'm trying to return it to the correct baseline without guessing. Sorry, forgot to ask the most important questions in the post. 1990 W-body LH0 3.1 MPFI 1227730 ECM (not confirmed); thanked the Lord it wasn't a snake. 8192 baud ALDL Speed-density system
  3. I have a 1990 Oldsmobile Cutlass Supreme W-body with the 3.1L LH0 and automatic (4T60). I'm using an ALDL cable with TunerPro RT to diagnose a no-idle condition. I'm trying to verify that I'm using the correct acquisition definition and calibration before I rely on the live data. Can anyone confirm: Which ECM service number and mask should this car use? Which ADX (or ADS) is the correct one for a 1990 LH0 W-body? Which XDF and stock BIN correspond to that ECM? Is A109 correct, or is there a better definition for this application? Has anyone successfully scanned a 1990 LH0 with TunerPro RT, and if so, what files were you using? Current symptoms: Fuel pressure is 38–40 PSI. Engine will run smoothly if I keep it alive with the throttle. It will not establish an idle on its own. Code 34 has appeared. Code 34 Cleared. MAP values appear reasonable (while running), but some other parameters don't seem to decode correctly. I have already verified ignition wire routing and corrected several vacuum hose issues. I'm trying to verify my scan data before replacing any more parts. Dashboards 2026-07-12 16-05-16.mp4 Dashboards 2026-07-10 19-48-52.mp4
  4. Yesterday
  5. Last week
  6. Jscott
  7. 55trucker
  8. Earlier
  9. So I bought an old Matco 4000e scanner. Came with a pathfinder 2 cartridge and just a ford cable. I want to locate or make a harness for that to fit a GM obd1. The unit has a db25 male connection on it. But it also needs to be powered up too… any ideas would be a great help. Thanks.
  10. sadolboy48
    89 olds swaybar
  11. 55trucker
    89 olds swaybar
  12. sadolboy48
    89 olds swaybar
  13. 55trucker
    89 olds swaybar
  14. sadolboy48
    89 olds swaybar
  15. Psych0matt
  16. rich_e777
    89 olds swaybar
  17. 94 olds vert
  18. 55trucker
    89 olds swaybar
  19. Runs rough. New coils plugs wires after hot.
  20. Raffaelli
    89 olds swaybar
  21. sadolboy48
    89 olds swaybar
  22. sadolboy48
    89 olds swaybar
  23. Bake82
    89 olds swaybar
  24. sadolboy48
    89 olds swaybar
  25. sadolboy48
    89 olds swaybar
  26. 94 olds vert
    89 olds swaybar
  27. I have an 89 oldsmobile cutlass supreme 3.1 my front swaybar broke on the passengers side, not inlinks, it doesn't have any, the whole bar broke. Been looking everywhere for some kind of replacement. Just wondering if anyone knows any kind of other car that I can use one from because I can't seem to find any. Never seen a whole sawybar break but sure didn't think that it would be so hard to find one. The ones I can find are either for earlier or later models that do have inlinks and they won't fit.
  28. Thanks! Looks like they both use the same fcs rear shock/strut assembly according to rockauto. I'll definitely keep in mind looking into springs as well.
  29. Another on-line resources for checking part compatibility is a recycling yard search engine site called car-part.com. The search results can be set to include "All Interchange Choices", so that the search results include vehicles with parts that fit your vehicle Or you could call a recycling yard and ask about interchange options.
