  1. Yesterday
  2. Raffaelli
    OIL LEAK - 1994 Cutlass LQ1
  3. bluecalais79
  4. Last week
  5. 94 olds vert
  6. bluecalais79
  7. 55trucker
    Sunroof help again.
  8. Jscott
    Sunroof help again.
  9. bluecalais79
  10. GnatGoSplat
  11. 94 olds vert
    anyways, welcome to the site.
  12. Psych0matt
  13. bluecalais79
  14. RPE1992GPSE
  15. Good day, I have been a W body enthusiast since high school 04. In my student parking lot, we had a 93 Gran prix, 94 olds cutlass supreme, 94 cavalier z24, 95 monte, and my lumina z34. These cars were everywhere! My first car was a 94 lumina z34 (still have it). In 2012 I put a 4.9 PFI in it and it is almost complete. I just need to replace the rear suspension and odds and ends. I have a 99 Monte (needs some work), and I just picked up a decent (needs some work) Cutlass supreme. I am buying a new top for the cutlass on Friday. I want to get black canvass instead of the white (the car has black leather interior). They come in black, grey, white, red. What do you all think would be the best color? Just curious. Very few of these ole buggies still around (at least in my area). I thought I would join the forum to see what you all are up to (I feel very late to the party). I already have seen some super nice examples of these cars (nice job everyone!). Ill post more as spring hits and I can get them out, and work on them more. Also, not adverse to loading them up on the trailer for any meets that might happen. Thank you! Hope you all have a wonderful day!
  16. Bake82
  17. White93z34
  18. GnatGoSplat
  19. bluecalais79
  20. 55trucker
    1972 cutlass convertible
  21. I’m looking for the left driver side rear top rail. It connects to the left rear panel.. Need asap
  22. I’m looking for the left driver side rear top rail. It connects to the left rear panel.. Need asap
  23. GnatGoSplat
  24. GnatGoSplat
  25. RPE1992GPSE
  26. GnatGoSplat
  27. GnatGoSplat
    GM part number for Eaton supercharger on Series I 3800 v6
    91-93 88984224 94-95 12480745 Hope that helps.
