  2. Looking for info for parts..... anyone here available with info?
  3. Yesterday
  4. I think I used a 2x4 between the studs to twist it.
  5. Last week
  6. Raffaelli
    Fuel Pump Replacement
  7. ctaco
  8. GnatGoSplat
  9. ctaco
  10. ctaco
  11. GnatGoSplat
  12. Raffaelli
  13. ctaco
  14. ctaco
  15. 55trucker
  16. Raffaelli
  17. ctaco
  18. GnatGoSplat
  19. GnatGoSplat
    Drain tubes for convertible....
    Probably need to reseal your back window (windshield urethane is what I used). Mine had no drain and used to collect water, but I resealed my back window and it never collected water ever again.
  20. Topless1994
    I know this is an old thread but having the same problem. Can anyone help?
  21. Earlier
  22. bluecalais79
    A/C Repair - LQ-1
  23. Black92GS
  24. 32 Clicks of Rebound Force Adjustment (I'm assuming single)
  25. The softer the spring one uses the stiffer the dampening that's needed to keep ones ride from *floating*. Are these Rev9 shocks single or double acting?
  26. Well, crap, I'm an idiot Spring Rate(FRONT): 8 kg/mm (448 lbs/inch) (8k) (Spring Rate(REAR): 5 kg/mm (280 lbs/inch) (5k) https://www.ebay.com/itm/363295804829 BC (from ZZP): 5k Front, 6k Rear ZZP: 6.6kg front spring rate, 6.6kg rear spring rate Looks like I'm going to switch the fronts out for probably 6k if I can find them in 200mmx62mm (7.87" x 2.44") and try that. I believe the other ones use 10" springs, but I'll have to measure the other car this weekend.
  27. Hmmmmmm.......... the Rev9 supplier doesn't disclose the coil spring rates to the customer? is it safe to assume you're using the 97-04 Buick Regal coils? https://coiloverkits.com/collections/rev9-coilovers/products/buick-regal-coilovers-1997-2004-rev9-hyper-street-ii-32-way-adjustable
  28. I have Rev9 coilovers on my 2001 GT. I have 0 pre-load, which helps, but they're still a little bouncy and harsh no matter what I set the damper setting to. I have ZZP coilovers on the red car and, while not perfect, they are much better. I'm trying to figure out what spring rate they are or if anyone knows what I should swap them out for? I'm also going to grab more collars so I can lock them together. They keep coming loose. They have a thin lock washer, but one of them broke.
  29. White93z34
