Drain tubes for convertible....
Ian reacted to a post in a topic:
Toohfu joined the community -
AFM_Hater69 joined the community - Earlier
55trucker started following 1st Gen W body 14" wheels? and Coilover Spring Rates -
Mrob75 joined the community -
Sway bars just fell off the frame not too long ago and one of the front wheels is pushed up farther than the other one right where he said the subframe cracked.... Rear driver side has a decent hole through the frame too. Was told it was completely unsafe to drive at this point so I only drive it here and there. Will probably drive it until it gives out completely or part out within next couple years.
