  1. Yesterday
  2. rich_e777
    Wheel fit
  3. 94 olds vert
    New to this place. Hello.
  4. 55trucker
  5. Last week
  6. 94 olds vert
  7. Hi, I have a 92 Chevy Lumina Z34 automatic with the V6 DOHC. It's all stock. I am new to fixing cars and got it a year ago. Any tips or suggestions is appreciated. The current thing I'm working on it wiring and brakes.
  8. RPE1992GPSE
    Should I go back to stock?
  9. There's a guy in Denver that we used to use a lot that checked mine out that might be worth talking to: Steve's Transmissions and Gears 303-744-7904
  10. carkhz316
  11. 55trucker
    Wheel fit
  12. rich_e777
    Wheel fit
  13. Psych0matt
    Wheel fit
  14. It shouldn't be much lower than it was, but I definitely should get it aligned again. It's hard to tell since I had them all the way apart. I should have measured the wheel gap and/or fender height from the ground before and after, but I didn't for some reason.
  15. pwmin
    Wheel fit
  16. I'm seeing -.65 on both front wheels as the finished setting by the shop, that's a little more than negative half a degree. You're at just under 1 degree negative on the rears. I personally wouldn't adjust those at all, but those settings were done 2 years ago, you've had the front end apart & the car now sits lower, that will alter those earlier settings to some degree. Lowering the car will induce more negative camber.
  17. I'm at just under - 1. I raised it a little more.
  18. Go4DaMo
    Wheel fit
  19. Go4DaMo
    Luminac
    Unsubscribe
  20. Go4DaMo
    1st Gen W body 14" wheels?
  21. I do, so I'll have to check later and reference my alignment printout.
  22. I don't have a 2nd gen GM service manual so I do not know what the factory set the camber to.
  23. I can't recall, but it's close to stock. I think I should probably be able to go more negative without issue.
  24. You could dial in a little more negative camber on the fronts....do you know what the current setting is? One doesn't want to go *stupid* dramatic with negative.
  25. Gotcha, yes they are only single adjustable (rebound). Stiffening them up seemed to help in the past when the rears would do that, but could have just been in my head. I would go lower if I could, but they would hit a lot because of how close the tire is to the outside of the fender. That's what I get for living the "stance" life. I'll have to make due with the shocks I have. I don't think there are any coilover options for these with double adjustable ones. I could probably make something work if I researched enough, though, but I am much happier with the ride now.
  26. You're getting contact with the fender when the spring compresses, the shocks if they are single acting they don't dampen when compressing...only when they rebound. If what you have is an acceptable ride (not bone jarring) & the ride height is where you want it (even tho the fender is close to the tire), then what I suggest is a double acting shock that provides dampening in both directions. Seeing as you have mounted coil-overs you may be able to find double acting shocks for that setup.
  27. I'm talking about the strut dampening adjustment.
