GnatGoSplat reacted to a post in a topic: Whats the point of these strut “wings”?
GnatGoSplat started following 92 (88-94?) sunroof relay and Mono spring delete or suggestions
Loctite Hysol 11C glue is actually a really good 2-part epoxy. I use it to repair lots of things. I keep it inside, but the shelf life has been pretty good, lasting over 2-decades. Used it last December and it was still good. That Dorman kit worked pretty well for me, I think I repaired at least 2 W-bodies with it and never had a repeat repair. Shame it's not sold any more. It was supposed to be equivalent to OEM replacement ends and looked identical, so you didn't need the Moog blocks with them. - Today
JulienStocola joined the community
Ric started following 1993 Cutlass convertible top not moving, down or up
