I sourced a Dorman 924-980 and according to all the sites is a direct replacement for the 1995 Buick Regal. However, upon closer inspection it doesn't look right at all: Instead, Dorman 924-748 looks more like a direct replacement: Can anyone confirm the right after market part here? Again, Dorman's own site is suggestion the first as the direct fit.
I honestly don't know if they're low drag or not. I've never seen anything referencing that in SI or anywhere. I did find in the meantime, a thread by Miko K where he uses a 2nd/ 3rd gen MC with a 1" bore and installed it in his Cutlass. The biggest difference being two line outputs instead of 4, but he T'd them on the car to split the 2 channels to feed the 4 corners. -
Schurkey replied to carkhz316's topic in Brakes/Suspension/Steering/Wheels/Tires
"Bigger" master cylinder bore = less hydraulic advantage. If you have low-drag front calipers, you NEED the OEM three-chamber, step-bore, Quick Take-Up master cylinder. But I don't know if you have low-drag calipers. -
The Monte is pretty simple and old school. All the warning lights are just regular 194 light bulbs. So I was just planning on removing the ABS light bulb and the EBCM. I was curious about the MC bore sizes, since bigger would typically be better unless I'm overlooking something. -
Since you're already disks, and using the 1st gen booster, I'd grab a 1st gen master cylinder and re-do the lines as needed. Only thing I'm not entirely sure has been ever discussed has been the bore size of the master. I see there is 7/8 and a 15/16 size bore. I'd ensure you're getting the biggest bore for the disks. Otherwise - not sure on tuning or flashing the BCM to de-activate the ABS so you don't have a light on at all times. -
What I used for bushings is simple rubber vibration isolator pad material (the pad was approx 12" square), up here we have a *Princess Auto* hardware/automotive supply store, Harbor Freight *might* have something similar, using my table saw I cut the bushings to the same basic shape as the original molded bushing glued to the leaf & removed the material in the inner section to make the *pocket*. One has to do them in two pieces (upper & lower). One can *fine tune* the installed height of the new spring by adjusting the upper bushings thickness, but both bushings have to be no thicker than necessary to allow the spring to go into place & tighten up the lower mounting retainer to let it bottom against the stop. Seeing as the blank leaves are 3" wide (that's wider than the glas leaf in the centre section at the mounting points) I used my 5" angle grinder with a flap wheel to notch small recesses into the edges of the steel where the pads will go to allow the mounting bolts to slide up either side of the leaves up into the subframe member. All of this wasn't difficult, it just took time & patience. If you've never removed the rear leaf without the special spring compressor there is a way to get it out without to much fuss. -
VERY much appreciated - and thank you. Do you have any pics from install or how you made the rubber bits (Im guessing both center rubber and end rubber had to be made/cut) Agian, thank you! -
Flaring and making lines in no issue. I have benders and a hydraulic flaring tool which makes making lines a breeze. If I have enough line, I'd just bend and reattach, but I may make some unions otherwise. I know GM likes to make oddball thread and line sizes at the MC, so no surprise there. -
55trucker started following Monte Carlo Z34 brake master cylinder options/ ABS delete?
55trucker replied to carkhz316's topic in Brakes/Suspension/Steering/Wheels/Tires
Being an ABS VI you will have to either re-bend the existing lines at the current ABS module to fit into the 4 ports of the non ABS master or add extensions onto what's there. What's not known is if what is there right now will have the same 4 different line nut fittings that the non ABS master makes use of. Each line nut that goes into the appropriate master port has a different thread pitch & diameter so they could not be mixed up. -
Disc all around. -
Do you have drums still in the back? -
carkhz316 posted a topic in Brakes/Suspension/Steering/Wheels/Tires
As the title states, I'm looking for any/ all info in regards to the proper master cylinder needed for ABS deletion. I'm only wanting/ needing to do it in order to fit turbocharger piping in the engine bay, and not because of some naive safety circumvention. I am already running a smaller first gen brake booster found on the manual transmission cars if this matters. While searching RockAuto, there seems to be a lot of overlap between the 1st gen W-bodies through 1.5, with and without disc brakes, etc. So, I figured I'd ask the experts since I've seen brake systems discussed here in the past. Thanks! -
"Automatic shoulder belts" -
Would you happen to have the "Specs" the shop used, that could be taken to another shop (local to me in this case)? Thank you! - Earlier
Gotta love that quality 80s GM fit and finish! And that Regal is very oddly equipped. Bench seat, manual locks and windows, no rear reading lights.....but it has alloy wheels. Then there is this: That cluster must be from a pre-production vehicle, as the tach was never red like that on any of the production ones. My old 88 Regal was a November 87 build, and the tach was green like the rest of the cluster. -
94 olds vert replied to miltonv81's topic in Cutlass Supreme Convertible
I had a similar problem on a 2010 GMC sierra. The drivers side door window would only operate when the door was open. I dug into the wiring and found a wire that was nearly broken. I would check wiring and grounds. -
miltonv81 started following 1994 cutlass convertible windows
Here's me issue. Alternator died and the windows and top quit working along with all the guages. Replaced alternator, guages are back working but the windows now when you turn the key on they will work sometimes and sometimes not in conjunction with the top. Open the door when they are working all is fine till you close the door past the second detent then they quit working. Initially thought it was the circuit breaker and that is assuming the same breaker controls the windows and top. Now thinking the connector for the door to body but I wouldn't think the the wiring for the top would go through that connector, no sure. any body ever experience this?
