  2. Jscott
    Sunroof help again.
  3. Today
  4. Psych0matt
    Sunroof help again.
  5. Hey guys, kind of sad to see this community fade over the years, but hopefully some of you have some thoughts on this. I bit the bullet and put a new engine in my ‘92 CS Convertible, 3.1L. Most of the top parts were transferred over to the new block. Old engine ran fine before, but blew out the LIM and hydrolocked. Runs and idles great now, but above say 30 mph I get sputtering/misfiring on acceleration under load. Any ideas? ICM and coil packs only have a few thousand miles on them. New plugs with engine install. Wires are almost new. Car sat for several months with 3/4 tank, Stabil added, but the fuel is about 10 months old. Swapped TPS. No difference. Vacuum looks good. Older fuel? Fuel filter? Bad injector(s)? MAP? I’m going to take it back to the mechanic if I can’t figure it out myself. IMG_7976.mov
  6. Jscott
    Wiper won’t stop running
  7. Jscott
    Sunroof help again.
  8. Jscott
    Sunroof help again.
  9. Psych0matt
    Sunroof help again.
  10. Yesterday
  11. Black92GS
    Sunroof help again.
  12. Jscott
    Sunroof help again.
  13. Psych0matt
    Sunroof help…
  14. Last week
  15. I had this issue with my '95 CS convertible when I first got it in September 2018. I replaced the sensor and that solved the issue. I can't remember whether the part was OEM or aftermarket. I think I ordered it off of eBay, so it may well have been an aftermarket replacement. It was a pain to install without removing the radiator from the car. I had to use a hammer to lever it into place. I lost a fair amount of coolant in the process, so there was obviously plenty in the system.
  16. Human
  17. Please
  18. What cars can you modify moldings, and which ones to work on a 92 Olaf’s cutlass convertible?
  19. Greetings forum members! New member, so thought I'd take a moment to introduce myself. Last Spring (2025) I acquired a relatively pristine (54k miles) 88 Pontiac GP SE. I hadn't even known they made these with a 5-speed, so I hadn't explicitly been looking, yet lo and behold here we are. I've got it on good authority I'm only the second owner. It started life in central NY but spent the last 10 years parked in a sweltering hot garage in central Florida. It was never ever even registered in FL. So it's got some internal heat damage, which I've been repairing. The door upholstery glue had given up years ago. The stereo was a mess, but I replaced all of the capacitors on the amplifier boards and even plumbed in a bluetooth module to the cassette inputs. I'm not much of an auto mechanic myself, I do cybersecurity for a living, but I don't mind getting my hands dirty on projects like this. On the serious mechanical side, I've had it at a local "rural mechanic" who's did a flush on all of the fluids, changed out the master/slave cylinders, and replaced the brakes. I seem to have dodged the bullet of any serious rust or corrosion, but I know these are prone to rotting out their rear strut towers so I plan on installing a strut tower brace and blast the insides with as much cavity wax as they'll take. Any other "gotchas" tips, tricks, or suggestions for keeping something like this roadworthy? Google's AI guestimates, based on statistical analysis of scrap rates versus production numbers, there may only be 15-25 "roadworthy" versions of this model, trim, and transmission combinations left anywhere I didn't buy this planning on a super rare preservation "duty" yet here I am...any suggestions would be greatly appreciated. Don't worry, despite living in the salt-belt, I don't plan on driving it in winter for that reason...I do hope to drive it during the warmer months though! An 88 GP was my very first car when I turned 16, so I'd always been looking for a decent one, "just for fun". I never planned on ending up with a bigfoot-riding-a-unicorn of rarity...something I'm not all together happy about...yet here we are!
  20. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  21. Jscott
    Sunroof help…
  22. Psych0matt
  23. bluecalais79
  24. Earlier
  25. Psych0matt
    Sunroof help…
  26. Jscott
    Sunroof help…
  27. So I was watching old motorweek episodes on the 1st gen W-Bodies, and grabbed some screen caps comparing the times motorweek got. I realize this isnt bible but its interesting nonetheless! Of note - the quad 4 manual cutlas was the fastest of all to 60, but had a lower trap speed than the TGP and Z34. Clearly the Quad 4/manual was a good choice for this car performance wise - and their commentary on handling was that it was excellent (the most praise of the four) The TGP had the quickest 1/4 mile time, but not trap speed. The video showed very little wheelspin which clearly aided it off the line. The Z34 5-speed had a ton of wheelspin and tire smoke which seems to have limited its 0-60, but its trap speed is by far the highest. Clearly without the wheelspin this would be the “fastest” w-body and demonstrates the best power to weight. The 90 STE turbo was painfully slow compared to the rest, and especially the TGP. Given that its the same powertrain and the coupes and sedans are negligibly different weight-wise, this was either on a very hot day, or they just didnt have a very fast example (maybe a “friday car”)
  28. Rough budget I’d expect $1000 for parts car $500 clutch (spec 2+/3+) $300 flywheel (buy pre cut down and balanced from Fiero Rog in the Fiero Facebook groups) $200 fluids (trans fluid, coolant, oil etc) $200 clutch/flywheel bolts (GM tty bolts are pricey) $100-200 passenger side axle this doesn’t include any fabrication costs and any other “while you’re in there” costs and assumes you are doing all of the labour I’m sure you can do it cheaper but id be budgeting up to $3,000 all said and done
  29. Hopefully you get a notification to see this since it's been so long but I'm thinking about trying this in the future once it's not my daily but do you have any idea how much it was to do this
  30. Black92GS
