I've been hitting my head against the wall trying to figure this out. After several failed attempts to locate anything for the 1992 GTP, I had an idea. Don't know if it's possible but it might me. Would it be possible to replace the relays in the original connector? Either using the ones in the new unit or ordering NAIS relays. I'm sure that might be the only issue. I would assume you've already inspected the solder joints for any cracking.
X -
