  2. Today
  3. White93z34
    1990 Turbo Grand Prix Radiator needed!
    You're the person I've been hoping would come along. I have 3 of them, all cores, all need rebuilt. I don't remember what the issues were with each individual one I can pick through and grab the least worst looking. Is it also missing its intercooler? i have one more of those too.
  4. Yesterday
  5. Hello, I recently purchased a 1990 Grand Prix Mclaren to save it from being parted or scrapped. The radiator is missing but other than that everything is there, I would be so happy just to find a core that needs rebuilt at the least. I seen members of this forum years ago said they had radiators for this car, any chance they or anybody else does?
  6. Last week
  7. Yeah, I'm thinking the bulb swap will be the easiest part. Getting the gauge cluster out of the dashboard and putting it back in will most likely be the more challenging part of the operation. At this point, I'm still waiting for the LEDs to be delivered. Tracking shows they arrived in my city yesterday, and they were supposed to be delivered today, but now they've gone to a neighboring city. Such are the mysterious ways of the U.S. Postal Service. I also remembered last night that I have a GM shop manual for that Cutlass (all except the actual convertible supplement) that would likely have some useful diagrams and information. I've just got to remember where I put the thing.
  8. From what I remember replacing bulbs was very easy.
  9. The LEDs are due to arrive tomorrow. Not sure how much time I'll have this weekend to work on it. I did find this somewhat less than informative thread: At least now I have an idea of what the back side of the gauge cluster looks like. Looks like once I remove the cluster, I'll have to take that black panel off to get to the bulbs.
  10. Once the bezel is off remove the screws around guage cluster it shoud come out. The back is a printed circuit board , you’ll see how the bulbs come out. replace each with the correct led, you need to get a bulb chart for your car , it might be in your owners manuel, or in the service manuel. Reach our maybe someone can put photo of bulb chart and info on removing your year cluster. good luck
  11. jadeshearwater960
    Should I go back to stock?
    Those modules being shared across so many GM models at least makes finding a usable replacement less of a unicorn hunt. The Tech 1 diagnostics are wild for a factory radio from that era.
  12. rich_e777
    TBH I thinks its going to take exactly that, but not before this and then might as well replace that. But then oh if we`re going this far might as well go all in or it wasn't worth putting in at all because it just isn't the right way. Le Damnit`e Its under a cover for the most part while I sort out some non-brake related issues, highly recommend Seal Skin for covers.
  13. Back during the recession in '08 these cars littered the junkyard. I used to stack up on parts.
  14. nimbletern88
    89 olds swaybar
    Could be worth checking old Regal and Grand Prix listings too, people often part those out without tagging the suspension bits. That early loop-end setup really narrows the hunt.
  15. I can agree about the headlights. Their performance is about average for the mid-'90s. I looked one time for a replacement headlight switch, but couldn't find one with the fog light switch, so I doused the one on my car with contact cleaner. It might have helped a little.
  16. I remember my 94 CS, and the dash lights were always bright.The headlights not so much. Replacing the headlight switch did fix some intermittent dimming issues
  17. Thanks for the video. That is exactly what mine desperately needs! It's great to get an idea of what it might look like with the LEDs in place. I realize your dash is different from mine, but how much trouble was it to swap out the bulbs for LEDs? Was anything else needed or was it just a direct swap? I've had the dash bezel off on mine several times, swapping radios, but I've never taken the gauge cluster out. I'm really looking forward to being able to see my instruments at night.
  18. Earlier
  19. I changed most of the dash , interior and exterior bulbs on my ‘94 cutlass convertible to led , I purchased most of what l needed on ebay. There’s a video showing what it looks like at night. IMG_3530.mov
  20. I just ordered some LEDs to replace the OEM bulbs ($8.89) for a box of 10. They're supposed to be a direct replacement for the bulbs and brighter to boot. We'll see. There were several color options. I briefly thought red might be fun, but I decided white would be the brightest.
  21. It does not appear that any bulbs are burned out because the lighting is uniform, albeit ridiculously dim, across the panel. I can imagine that dust might be a possible culprit. I've just got to figure out how to get in there to clean off the bulbs. I have also noticed the other evening is the panel lights were fairly bright when I first turned the lights on, but then quickly became progressively dimmer. I can still see the needles, just not what they're pointing to. It's also possible that could be an optical illusion caused by changing levels of ambient illumination (e.g., street lights, headlights from other vehicles, etc.). If I end up replacing the bulbs, I would want to investigate options for brighter ones. Meanwhile, I'll continue to endeavor to minimize nighttime driving as much as possible.
  22. Well, a 95 is now 31 years old... a lot has changed since then. Possible that the bulbs are dusty/dim you could try replacing the illumination lamps in the cluster - perhaps one or more is burn out. Or perhaps we're just spoiled by new cars and thats just how it is...
  23. So, I'm without my daily driver (2013 Buick LaCrosse) for a couple of weeks, and my '95 Cutlass Supreme convertible has been pressed into daily driver service. This is fine during the daytime, especially when we've been having afternoons in the mid-'70s, which is perfect drop-the-top weather, but after dark? Not so much. The instrument panel lights are so dim, I can't see the speedometer, especially when a jacked-up SUV or pickemup truck shines its way-too-bright headlights in my rearview mirror. I can't imagine they were this dim when the car was new. There's got to be a fix. Oh well, I just have to remember to be glad I have transportation.
  24. My car is currently at the mechanic after the technician repaired my main engine harness, I guess when I put my engine back together I smashed the harness behind the AC compressor bracket. Mechanic ended up bypassing To a known good 5 Volt reference after he got the same numbers that I got when I back probed my MAP, IAC and TPS. He then informed me that I had board damage on my ECM and that a 12 Volt being fed to my ECM couldn't have been good. I ended up purchasing a spare ECM. I'm preparing to head there and connect TunerPro RT V6 to my 1990 Oldsmobile Cutlass Supreme 3.1L LH0 V6, 4T60 automatic, using a GM 12-pin FTDI ALDL cable. The vehicle originally had a 16198260 ECM, and I purchased a replacement 1227727 ECM. The replacement arrived with an ARZW MEM-CAL. I'm still confirming whether my original MEM-CAL was transferred. My engine has the three-solenoid digital EGR valve. I currently have A109.adx loaded, converted from A109.ads, and corrected the Transmit Stream Reply body size from 66 to 67. I'd appreciate clarification on four questions: Is A109 the correct 8192-baud ALDL data-stream definition for the 1990 W-body LH0 with digital EGR, or should I be using the $88 acquisition definition? Has anyone successfully used A109 with the 1990 W-body 1227727 ECM and original $88-family calibration? Are there any additional ADS-to-ADX conversion settings I need to verify in TunerPro RT V6? What's the best way to confirm that the ECM is transmitting valid packets, rather than merely establishing serial communication and displaying incorrectly decoded parameters? The engine has exhibited incorrect sensor-reference voltage, rich running, injector-control problems and unreliable starting. The mechanic has repaired damaged wiring, and I'm preparing to collect a fresh KOEO/cranking XDL recording. I'm trying to verify the acquisition setup before interpreting the live readings or considering additional ECM replacement.
  25. umbersparrow414
    4T65E Range Selector Bracket
  26. bluecalais79
    Front Dash Speakers
  27. rich_e777
    Front Dash Speakers
  28. bluecalais79
    Front Dash Speakers
  29. 94 olds vert
    Front Dash Speakers
  30. bluecalais79
    Front Dash Speakers
