Go to solution Solved by 55trucker,
I have a 1990 Oldsmobile Cutlass Supreme W-body with the 3.1L LH0 and automatic (4T60).
I'm using an ALDL cable with TunerPro RT to diagnose a no-idle condition.
I'm trying to verify that I'm using the correct acquisition definition and calibration before I rely on the live data.
Can anyone confirm:
  1. Which ECM service number and mask should this car use?
  2. Which ADX (or ADS) is the correct one for a 1990 LH0 W-body?
  3. Which XDF and stock BIN correspond to that ECM?
  4. Is A109 correct, or is there a better definition for this application?
  5. Has anyone successfully scanned a 1990 LH0 with TunerPro RT, and if so, what files were you using?
Current symptoms:
  • Fuel pressure is 38–40 PSI.
  • Engine will run smoothly if I keep it alive with the throttle.
  • It will not establish an idle on its own.
  • Code 34 has appeared.
  • Code 34 Cleared.
  • MAP values appear reasonable (while running), but some other parameters don't seem to decode correctly.
  • I have already verified ignition wire routing and corrected several vacuum hose issues.
I'm trying to verify my scan data before replacing any more parts.
Can someone with a stock 1990 LH0 W-body tell me exactly which ADX/XDF/BIN combination they're using with TunerPro RT? Also does anyone know the factory procedure for setting the throttle stop screw on a 1990 LH0 throttle body? Mine was previously adjusted, and I'm trying to return it to the correct baseline without guessing. Sorry, forgot to ask the most important questions in the post.
  • 1990 W-body
  • LH0 3.1 MPFI
  • 1227730 ECM (not confirmed); thanked the Lord it wasn't a snake.
  • 8192 baud ALDL
  • Speed-density system
  • 1990 W-body
  • LH0 3.1 MPFI
  • 8192 baud ALDL
Where'd you get  a *730* ecm from? That's an all metal cased unit, it was not put into the W body cars. There's no way to mount it at all.
The proper ecm for your car would be the 1227727 ecm. Seeing as you have the incorrect ecm you more than likely do not have the correct memcal chip as well.
Thanks. I should have worded that better. The 1227730 is not confirmed. I only listed it because I found TunerPro definitions that referenced the 1227727/1227730 family. I haven't physically verified the ECM service number yet.
Before I pull the ECM, can someone confirm the factory ECM service number and MEM-CAL for a stock 1990 Cutlass Supreme 3.1 LH0 W-body? Also If the factory ECM is 1227727, which TunerPro ADX and XDF are you using for a stock 1990 LH0?
Edited by CuttyBawl
You understand that because you're dealing OBD1 the ECM mem cal's are tuned to the specific vehicle powertrain the mem-cal is plugged into for particular vehicles ECM.
If one is attempting to do custom chip mods you can't just use a program such as TunerPro to alter the mem-cal, you have to burn a new eeprom blank chip (27C256) to fit into the chip housing that plugs into the mem-cal slot.
To burn the chip you will need the physical Moates chip burner, a laptop with the Moates software on it to read the existing mem-cal, extract that BIn file, then you have to write the new BIN program with the Moates software & then command the burn of the new blank chip. To be honest one usually doesn't get it right the 1st time.
Here is the list of GM OBD1 ECMs & the accompanying MEM-CAL ID's. Yours will the 1227727. Your engine code is *T*,  the mem-cal will be for either auto or man trans.
Your mem-cal has a sticker attached to the mem-cal, pull the ECM inspection cover, the mem-cal is right below the cover for easy access.
The ECM is easy to recognize, open the hood, in front of right side shock tower under the plastic cover, bolted to the shock tower.
https://pcmhacking.net/ludis/p4xref.html#1227727
Edited by 55trucker
Thanks, that's exactly the information I was looking for. I haven't physically verified my ECM yet. I'll check the passenger-side shock tower under the hood and report back with the ECM service number and MEM-CAL ID. Since my car is a 1990 Cutlass Supreme 3.1 LH0 with an automatic, can you tell me which stock MEM-CAL ID I should expect to find?
Edited by CuttyBawl
Thank you  for pointing me to the correct location. I found the ECM under the passenger-side strut tower. I uploaded three photos of it. The only label I can see is the Delphi remanufactured sticker (SVC #16198260). I don't see an obvious inspection cover or small access panel for the MEM-CAL. Before I start removing mounting bolts or unplugging connectors, can you tell me exactly which fasteners need to come off to access the MEM-CAL and read the original GM ECM service number? I don't want to damage anything or take apart more than necessary.
  • Solution
The access cover on the shock tower side, you will have to remove the ECM & then you'll see the access cover.
Can't tell you for sure but the mem-cal will  could very well be the AUMY, pull the ecm, remove the cover & you'll see for sure.
 ECM/PCM Programming
  • 3 weeks later...
1227727 and 1227730 use the same chips.  One is waterproof and used in W bodies and Corvettes.
1990 is the only year to use $88 code mask. 88-89 are $6D.  91-92 is $A1.  93 is $DF.  Thats for the 3.1 V6.  The most common with all the data code layed out is $A1.  I would use A1 to start and modify from there (because I have been tuning these for over 20 years and can do this).
Edited by Vegeta
