Fuel Pump Replacement
I just dropped the tank on my Lumina a few days ago. Don’t cut a hole in the floor, it’s really not that hard, just kind of sucks to reattach the vapor lines.
 In a nutshell…
 -there’s an exhaust heat shield that had to come off.
-unplug 2 fuel lines, 3 vapor lines, the electrical connection, and two fuel fill pipes at the tank.
-15mm bolts on the straps, and it comes down.
It took me all of 10 mins to drop the tank. I’ve replaced the tank and fuel sending unit twice (from rust damage from sitting) and a third to reseal the sending/pump unit.
 Delphi pumps are good, but buy a GM fuel sending unit gasket. Don’t use aftermarket.
 In a nutshell…
