pwmin Posted April 8 Report Posted April 8 I have Rev9 coilovers on my 2001 GT. I have 0 pre-load, which helps, but they're still a little bouncy and harsh no matter what I set the damper setting to. I have ZZP coilovers on the red car and, while not perfect, they are much better. I'm trying to figure out what spring rate they are or if anyone knows what I should swap them out for? I'm also going to grab more collars so I can lock them together. They keep coming loose. They have a thin lock washer, but one of them broke. Quote
55trucker Posted April 9 Report Posted April 9 Hmmmmmm.......... the Rev9 supplier doesn't disclose the coil spring rates to the customer? is it safe to assume you're using the 97-04 Buick Regal coils? https://coiloverkits.com/collections/rev9-coilovers/products/buick-regal-coilovers-1997-2004-rev9-hyper-street-ii-32-way-adjustable Quote
pwmin Posted April 9 Author Report Posted April 9 2 hours ago, 55trucker said: Hmmmmmm.......... the Rev9 supplier doesn't disclose the coil spring rates to the customer? is it safe to assume you're using the 97-04 Buick Regal coils? https://coiloverkits.com/collections/rev9-coilovers/products/buick-regal-coilovers-1997-2004-rev9-hyper-street-ii-32-way-adjustable Well, crap, I'm an idiot Spring Rate(FRONT): 8 kg/mm (448 lbs/inch) (8k) (Spring Rate(REAR): 5 kg/mm (280 lbs/inch) (5k) https://www.ebay.com/itm/363295804829 BC (from ZZP): 5k Front, 6k Rear ZZP: 6.6kg front spring rate, 6.6kg rear spring rate Looks like I'm going to switch the fronts out for probably 6k if I can find them in 200mmx62mm (7.87" x 2.44") and try that. I believe the other ones use 10" springs, but I'll have to measure the other car this weekend. Quote
55trucker Posted April 9 Report Posted April 9 The softer the spring one uses the stiffer the dampening that's needed to keep ones ride from *floating*. Are these Rev9 shocks single or double acting? pwmin 1 Quote
pwmin Posted April 9 Author Report Posted April 9 32 Clicks of Rebound Force Adjustment (I'm assuming single) Quote
pwmin Posted 22 hours ago Author Report Posted 22 hours ago So far, it rides better. I need stiffen them up a little because the tires scrub on bumps sometimes. 94 olds vert 1 Quote
Psych0matt Posted 17 hours ago Report Posted 17 hours ago (edited) I'm running (iirc) 450 and 350 and it's pretty dang tight, but not super stiff on normal roads (so it does suck sometimes around here haha). I'm gonna look back and see if I can find if my memory is correct edit: close, 400 and 350 Edited 17 hours ago by Psych0matt Quote
55trucker Posted 17 hours ago Report Posted 17 hours ago 5 hours ago, pwmin said: So far, it rides better. I need stiffen them up a little because the tires scrub on bumps sometimes. Stiffen them up? or raise the car slightly Quote
pwmin Posted 14 hours ago Author Report Posted 14 hours ago Already did that. They need a little more suppression. Quote
55trucker Posted 13 hours ago Report Posted 13 hours ago Don't know how one changes the spring rate of a coil, it's built into the springs particular design rating. Quote
pwmin Posted 28 minutes ago Author Report Posted 28 minutes ago I'm talking about the strut dampening adjustment. Quote
55trucker Posted 3 minutes ago Report Posted 3 minutes ago (edited) You're getting contact with the fender when the spring compresses, the shocks if they are single acting they don't dampen when compressing...only when they rebound. If what you have is an acceptable ride (not bone jarring) & the ride height is where you want it (even tho the fender is close to the tire), then what I suggest is a double acting shock that provides dampening in both directions. Seeing as you have mounted coil-overs you may be able to find double acting shocks for that setup. Edited 3 minutes ago by 55trucker Quote
