your biggest issue, I think will be the lack of a cam position sensor on a 3.1 and potentially lack of secondary crank sensor (if the 3100 has that, I'm not sure). I'm sure you don't care about things like o2 sensors and the like so I'm trying to think of things that would prevent it from just working. is a 3100 a MAF car? if it is are you even running a maf? not that I think it would matter as you could just slap that in line on a 3.1.
Transmission control might be a problem, but again not sure how much you care about that since you'd probably just be using first and reverse
Not sure how a 3100 PCM would cope with the lack of cam sensor signal, its possible that it would work.
Truth be told the stock engine harness in that car is pretty darn close to a stand alone system. I've also seen derby guys use modified 3.1 intake manifolds with a carb base welded on and a distributor out of a 3.1 U van if you really wanted to keep it simple
I agree.  I think trying to convert a 3.1 to run on a 3100 PCM solely for derby use is taking things a little too far.  Sure, you could probably get it to work somewhat without all of the necessary sensor inputs....but would it really be worthwhile?
If it were me....i'd either run the thing stock or carb swap it.  Trying to get it to run properly on an OBD2 PCM wouldn't even cross my mind.
