Jscott Posted Friday at 04:15 PM Report Posted Friday at 04:15 PM Ok. So I have 90 olds CS and I’ve been bagging my head trying to figure out why the sunroof won’t retract fully. It tilts fine. I thought it was an aftermarket sunroof but I checked the RPO code 5F3 which states it is factory. I was told that gm never made a fully retracting glass in those years. Is that true??? It’s just funny how they have a whole roof system with guide rails all the way back and only have a tilt option. Any insight would be appreciated. Thanks. Quote
Black92GS Posted Friday at 05:13 PM Report Posted Friday at 05:13 PM They're supposed to retract. They don't "fully" retract in the sense you no longer see them, but they're supposed to retract nearly all of the way. When I had my 92 Cutlass many years back, the sunroof didn't move properly. I believe the drive gear was stripped, and I ended up just pulling an entire sunroof unit from a car in the junkyard and replacing it. I also had the sunroof in my 2000 Regal break, to where it wouldn't retract properly, and would only tilt. I never looked into fixing it...but it acted similar to a power window with a broken track. Psych0matt 1 Quote
Psych0matt Posted yesterday at 12:33 AM Report Posted yesterday at 12:33 AM what do you m ean by wont retract "fully"? When all the way back there's probably 3" or so iirc that doesn't fully go back into the roof Quote
Jscott Posted yesterday at 11:39 AM Author Report Posted yesterday at 11:39 AM I just mean that when I toggle the switch it only opens to tilt. It feels like it’s not getting any power to open up. However the relay box says Inalfa with two relays and the control circuit panel. I thought Inalfa was an aftermarket sunroof company. Both of those relays open and close fine. Which button usually retracts the roof, the front button? Or rear? Either way it does nothing. Except tilt. Quote
Jscott Posted yesterday at 11:51 AM Author Report Posted yesterday at 11:51 AM I ordered 2 spdt relays thinking I could possibly hard wire it to replace that circuit board. Maybe that control board is bad. I don’t know. Cause like I said retract does nothing. Not even trying to open. Quote
Psych0matt Posted yesterday at 07:14 PM Report Posted yesterday at 07:14 PM does this sunroof "close" in between the vent position and the slid back position, or open->closed->vent? Or is it closed->vent->open? Quote
Jscott Posted 21 hours ago Author Report Posted 21 hours ago It’s basically a rocker switch with two contact pin on the backside. Looks just like the windows switches Quote
Psych0matt Posted 18 hours ago Report Posted 18 hours ago right, but what positions does the sunroof go in relation? The switch and relay setup are separate Quote
Jscott Posted 7 hours ago Author Report Posted 7 hours ago Just open to vent and close I not sure if that helps. When it closes all the way the glass drops a little below the roof line. Like it does when it’s supposed to retract back. But obviously never does. Quote
Psych0matt Posted 2 hours ago Report Posted 2 hours ago is it supposed to drop a little further, and then continue sliding back? I wonder if it's a bit tight and getting bound up. Mine kinda pops a bit sometimes after i haven't used it in a while, but being this old if the motor is a bit weak i could see that stopping it Quote
55trucker Posted 1 hour ago Report Posted 1 hour ago When retracting...... the entire glass frame lowers to below the roofline & then retracts along the runners to the full stop position at the back end of the runner assembly. When the assembly is in the *closed position* the glass is flush with the roofline exterior. Quote
