Sunroof help again.
They're supposed to retract.  They don't "fully" retract in the sense you no longer see them, but they're supposed to retract nearly all of the way. When I had my 92 Cutlass many years back, the sunroof didn't move properly.  I believe the drive gear was stripped, and I ended up just pulling an entire sunroof unit from a car in the junkyard and replacing it.
I also had the sunroof in my 2000 Regal break, to where it wouldn't retract properly, and would only tilt.  I never looked into fixing it...but it acted similar to a power window with a broken track.
I just mean that when I toggle the switch it only opens to tilt. It feels like it’s not getting any power to open up. However the relay box says Inalfa with two relays and the control circuit panel. I thought Inalfa was an aftermarket sunroof company.  Both of those relays open and close fine. Which button usually retracts the roof, the front button? Or rear?  Either way it does nothing. Except tilt.
