I had a similar issue for the past 10 years that I finally dealt with this past fall, the relay inside was acting up and it would only do the reverse position maybe 4% of the time, if not less. I literally had to sit there and keep clicking it until it would finally decide to take. It would always work on the reverse(?) side; so from vent to close, or from close to slide open, and it sounds like yours is having the reverse issue.
However, it depends on what unit you have, its possible its a vent only
but Here's the post. I ended up having to use a slightly newer relay module, I simply couldn't find an exact match, but they're pretty much the same thing. One thing is that on mine it has a stop switch since "closed" is in the middle of open and vent, where as newer cars such as my 06 go into vent mode and then slide back essentially still in vent mode but slid back, if that makes sense. Point being, I lost the stop feature since the newer unit doesn't have to account for that, but I'd rather lose that and be able to actually open and close it, I just have to make sure it's in a good sealed position, which isn't hard.
Here's the part number
if it's the same unit as mine (which I think it should be) then it would be worth a try. I did have to cut the plugs from the old one and rewire them onto the new unit, but that took just a few minutes
Edited by Psych0matt
