mikeytcarter Posted December 17, 2025 Report Posted December 17, 2025 Hello everyone! i have recently acquired a 2002 Buick Regal. This car was a one owner car and I picked it up in October with 74k miles on it. It has been very well taken care of. I bought this car because of the reliability factor, however I have fallen in love with how it drives! The only issue that I am having is intermittent headlight pulsing. It only happens when the car is decelerating and slowing down under 30mph or so. So far I have replaced the battery, had the alternator tested(tested good ), went and bought another alternator and installed just in case of possible voltage regulator. Also found and cleaned thee grounds under the fuse box, next to the drivers headlight, and the engine ground by the exhaust. I have also ran a big 3 wire upgrade (did this for future sound system) as well as an extra power wire from fuse box to alternator(saw some videos where people said this extra line helped)This seemed to make my headlights a bit brighter, but not affect on the pulsing. All that being said i am still getting the same result. The interior lights will dim for a moment when the car first starts and the the headlights on deceleration. From what I have found there is no headlight relay, only fuses. I have one friend who has suggested new bulbs, however I am not convinced this would fix anything as they are older but still light up well. Any suggestions on where to look next would be greatly appreciated! Quote
mikeytcarter Posted December 17, 2025 Author Report Posted December 17, 2025 (edited) 8 Edited December 17, 2025 by mikeytcarter Quote
Black92GS Posted December 17, 2025 Report Posted December 17, 2025 You'll have to define the pulsing. Is it like a continuous flicker, or is it more along the lines of a large draw where the lights briefly dim once and then come back up? Quote
mikeytcarter Posted December 17, 2025 Author Report Posted December 17, 2025 The latter would be a better description. It’s like a large draw and they will dim then go back to normal. Sometimes it does it once’s, sometimes a few times in a row Quote
Black92GS Posted December 17, 2025 Report Posted December 17, 2025 2 minutes ago, mikeytcarter said: The latter would be a better description. It’s like a large draw and they will dim then go back to normal. Sometimes it does it once’s, sometimes a few times in a row Ok. Now this may sound like a really weird question....are you absolutely positive that the ABS isn't activating when you're slowing down? The ABS pump activates briefly during its self check shortly after startup (or when you first start moving...can't recall which). In every 90s/2000s GM i've driven, including a 2000 Regal, the ABS pump initially kicking in would often cause a bit of a power dip (headlights dimming slightly, blower speed audibly slowing slightly etc..). Something that I have also had issues with in some of those vehicles has been unwanted ABS activation from weak/failing wheel speed sensors and/or failing tone rings. You may need to really listen and feel for an unwanted ABS activation, as it can range from being a very quick and random engagement of the pump that you don't really feel.... to full on constant ABS activation with the pushback of the pedal and the sensation of a loss of braking power. Quote
mikeytcarter Posted December 17, 2025 Author Report Posted December 17, 2025 Hmm I am not positive but that does seem to make sense given when its happening. Im not necessarily on the brakes when it happens, but sometimes just letting off the accelerator causes it. I have an Autel scanner. Would there be a way for me to watch for this using live data in some way? Quote
mikeytcarter Posted December 17, 2025 Author Report Posted December 17, 2025 Also just remembered when I first picked the car up one morning the ABS light did come on. All I did was shut the car off and it went away. Definitely think youre onto something now Quote
Black92GS Posted December 17, 2025 Report Posted December 17, 2025 25 minutes ago, mikeytcarter said: Hmm I am not positive but that does seem to make sense given when its happening. Im not necessarily on the brakes when it happens, but sometimes just letting off the accelerator causes it. I have an Autel scanner. Would there be a way for me to watch for this using live data in some way? I seem to recall my Regal doing that as well sometimes. I always attributed it to a delay between an increased electrical demand and the PCM increasing the duty cycle of the alternator to compensate. If your scanner can read ABS codes, you should be able to monitor individual wheel speeds. If it's just a generic OBD2 scanner, those usually can't read ABS data. 22 minutes ago, mikeytcarter said: Also just remembered when I first picked the car up one morning the ABS light did come on. All I did was shut the car off and it went away. Definitely think youre onto something now That's how mine started. The odd random ABS pulse, or the occasional ABS light coming on that would disappear after a restart. Eventually, I had to pull the fuse because the ABS began activating randomly at lower speeds and made things dangerous. Quote
mikeytcarter Posted December 17, 2025 Author Report Posted December 17, 2025 Ah dang, so you just run without ABS then? My scanner is bi directional so I am going to try and drive it later maybe pin point a bad wheel speed sensor Quote
Black92GS Posted December 17, 2025 Report Posted December 17, 2025 Just now, mikeytcarter said: Ah dang, so you just run without ABS then? My scanner is bi directional so I am going to try and drive it later maybe pin point a bad wheel speed sensor You don’t have to. I did because I was I was too cheap to fix it properly at the time. No ABS was far safer than unwanted activation. Sometimes, there is a bit of rust scale that builds up and lifts the sensor (rust jacking), changing the air gap and making the signal weaker and less reliable. Other times, the wheel hub begins to wear internally and can cover the sensor with metal filings, making the signal weaker. The sensors themselves can also go bad. If your scanner is Bidirectional, then the odds of it being able to read ABS data is pretty good. Quote
mikeytcarter Posted December 17, 2025 Author Report Posted December 17, 2025 Man thank you so much for all the info! Going to dive into this tonight and see what I find. Ill post tomorrow with the results Quote
mikeytcarter Posted December 18, 2025 Author Report Posted December 18, 2025 Good morning! So last night I took out the ABS fuse while I eas driving around. Unfortunately the headlights would still do the same thing I am still going to look into the sensors today as I do have a random grinding sound that will come and go from the rear, so maybe a bad wheel bearing. That being said do you think its something else since it still did it with the fuse out? I am also attaching a video of what the interior lights do at first start up. The noise and the way the lights act are very similar to the what the headlights do when slowing down. I had my park brake on this morning so didnt check the headlights unfortunately. Thanks in advance for the help, im still new to electrical so excuse my ignorance on next steps! 20251218_072241.mp4 Quote
Black92GS Posted December 18, 2025 Report Posted December 18, 2025 39 minutes ago, mikeytcarter said: Good morning! So last night I took out the ABS fuse while I eas driving around. Unfortunately the headlights would still do the same thing I am still going to look into the sensors today as I do have a random grinding sound that will come and go from the rear, so maybe a bad wheel bearing. That being said do you think its something else since it still did it with the fuse out? I am also attaching a video of what the interior lights do at first start up. The noise and the way the lights act are very similar to the what the headlights do when slowing down. I had my park brake on this morning so didnt check the headlights unfortunately. Thanks in advance for the help, im still new to electrical so excuse my ignorance on next steps! 20251218_072241.mp4 I'm going to be honest, I don't see an issue there. It cranked just fine, and the dip sounded like the AC compressor kicking on. The slight electrical dip is likely just a product of a slight lag between a large electrical load kicking in and the duty cycle of the alternator being increased adequately to compensate. primergray 1 Quote
mikeytcarter Posted December 18, 2025 Author Report Posted December 18, 2025 Okay 10-4, gonna try and get a video of the lights doing it tonight so you can see! Quote
Black92GS Posted December 18, 2025 Report Posted December 18, 2025 Please do. That slight voltage sag (dimming/fan speed drop) that took place above when the AC compressor kicked in is 100% normal operation for these cars in my view, and its just a byproduct of how the charging system is programmed to function. It can happen whenever a large electrical load comes on line at low RPM, and It is definitely visible in the headlights when they are on. My 2000 Regal did this all the time, and the factory alternator and the 6 year old battery were still fully functional when I got rid of that car in early 2015. primergray 1 Quote
primergray Posted December 18, 2025 Report Posted December 18, 2025 (edited) Check how hot the auxillary battery terminal gets...mine would get hot and cause voltage drops until I replaced it...previous owners thought it was just going through alternators. I had one of the zinc ones (and one with the bottom threads stripped so it was had a couple of washers for spacers and what appeared to be a Delco radio post nut as well) and replaced it with brass...common issue on the B bodies too, and it's the same process and part number for replacement. Might not apply on a 2000, though... Replacing the Auxiliary Battery Post | Page 3 | Chevy Impala SS Forum Edited December 18, 2025 by primergray mikeytcarter 1 Quote
mikeytcarter Posted December 18, 2025 Author Report Posted December 18, 2025 Okay I will look into it! And are you referring to the post that is on the top of the under hood fuse box? The pics in the forum thats what it looks like. Not the positive battery terminal itself right? primergray 1 Quote
Black92GS Posted December 18, 2025 Report Posted December 18, 2025 That's the one. It looks like you took care of it with your wiring upgrade though. mikeytcarter 1 Quote
mikeytcarter Posted December 18, 2025 Author Report Posted December 18, 2025 Yeah I cant see a second one on the box and the top post appears to be fine. Its definitely zinc though, do you think a brass replacement would do anything? Quote
Black92GS Posted December 19, 2025 Report Posted December 19, 2025 15 hours ago, mikeytcarter said: Yeah I cant see a second one on the box and the top post appears to be fine. Its definitely zinc though, do you think a brass replacement would do anything? Nope. As long as it's all tight and clean it should be OK. The loose aux post was more of an issue on the 1st Gen cars. Those used a brass post and nuts that were very easily stripped out and could cause issues. Quote
mikeytcarter Posted December 19, 2025 Author Report Posted December 19, 2025 Okay 10-4. After I looked into i saw they were different fuse boxes anyways. So last night took the car for a drive and the wheel speed sensors are all reporting accurately from what we could see. I had a friend monitor while I drive. And of course she didnt wanna actually pulse a whole lot so I couldn't catch a video. I am probably getting some black headlights with LEDs for Christmas.... maybe the LEDs will be the fix since they dont need as much power lol. I am also planning on adding a ground from the engine to the chassis so we shall see. If it still does it after all that im sure ill be back picking your brain thanks again for all fhe great info guys Quote
mikeytcarter Posted December 19, 2025 Author Report Posted December 19, 2025 Between the 6 and 7 seconds in this video you can see it if you zoom in. Unfortunately lots of light pollution from the other cars so kind of hard to spot 20251218_182451.mp4 Quote
Black92GS Posted December 19, 2025 Report Posted December 19, 2025 I don't believe you have an issue that warrants any concern if i'm being honest. I couldn't see the dimming, but I did hear when it took place. What I think is happening there is this: As you're coasting down, the engine cuts fuel and is freewheeling. Once you drop below to a certain speed/RPM, it will switch back to feeding fuel and to the IAC for idle speed control. The PCM is likely cutting the alternator output momentarily at the same time to make the overall transition smoother and to prevent stalling, but this will also result in a drop from charging voltage to battery voltage and then back. Non PCM controlled alternators monitor the voltage and self regulate based on that. PCM controlled alternators have the PCM monitor the voltage and the draw, and can adjust the alternator output as required. It also means they can reduce or cut the output completely in certain states to prevent other issues. If the alternator output is completely cut momentarily, you will immediately drop from charging voltage to battery voltage and then back once the alternator ramps back up. Halogen lighting output and blower speed will change along with this voltage change. primergray and mikeytcarter 2 Quote
primergray Posted December 19, 2025 Report Posted December 19, 2025 (edited) Maybe you'll want to look into something like this: https://www.summitracing.com/search/part-type/headlight-conversion-harnesses/product-line/united-pacific-headlight-relay-harness-kits Edited December 19, 2025 by primergray mikeytcarter 1 Quote
