pwmin Posted November 26, 2025 Report Posted November 26, 2025 (edited) I used to have heat, but it won't switch from cold anymore. Started intermittent, but now it's permanent. I'm thinking it's the blend door actuator. Any other things it could be besides a vacuum line? Is this the correct one and where is it located? Is it the one to the left of the glove box? I've replaced plenty on GMT800s and 2nd Gen W's. https://www.rockauto.com/en/moreinfo.php?pk=85484&cc=1056428&pt=10721&jsn=667&_nck=S9TpZc1fXxr7Xa7yUkP8%2BeVHrLluc6vJvrD2O9wgZs5RffpngaQG8wezeYP9fpHdOn5lato7smAZZ6tajgo%2ByAcvGnlbm7gWQ1k3lUBRwWeEUtTccaRuCow%2FiASFJvfjkuykQzPMOtbz3c9d3dg2Jwa2GXon2nPW456wgqIX0aMxZ6Nc%2B76i78Di5iBUsi33RWIvDIg08cGCapSM%2FcfHfndGUOG3yYrbav%2FLKA2juWh%2FAYpE3fgdKRVTmgyRZ5Lr3LTjS8N8aR7BaphHG3pne8D1vTbj5ru9dMoXwBdelgZ7crUL5rYxZZQYphmOI%2BTe&_nck=S9TpZc1fXxr7Xa7yUkP8%2BeVHrLluc6vJvrD2O9wgZs5RffpngaQG8wezeYP9fpHdOn5lato7smAZZ6tajgo%2ByAcvGnlbm7gWQ1k3lUBRwWeEUtTccaRuCow%2FiASFJvfjkuykQzPMOtbz3c9d3dg2Jwa2GXon2nPW456wgqIX0aMxZ6Nc%2B76i78Di5iBUsi33RWIvDIg08cGCapSM%2FcfHfndGUOG3yYrbav%2FLKA2juWh%2FAYpE3fgdKRVTmgyRZ5Lr3LTjS8N8aR7BaphHG3pne8D1vTbj5ru9dMoXwBdelgZ7crUL5rYxZZQYphmOI%2BTe Edited November 26, 2025 by pwmin Quote
pwmin Posted November 26, 2025 Author Report Posted November 26, 2025 and now it's working again. I ordered the one I linked to, so I'll probably just replace it anyway. Quote
pwmin Posted November 26, 2025 Author Report Posted November 26, 2025 Well, now it's only blowing out of the defrost. Fan is working, but I'm not sure about the heat/cold right at this moment. Quote
55trucker Posted December 3, 2025 Report Posted December 3, 2025 (edited) Well, defrost is the default direction for all optional failures, as for the heat can you get your hands around the inlet or outlet core piping to feel what the coolant temp is? if the blend door is stuck closed so the inlet air bypasses the core that would deliver what you're presently getting. One can see the actuators if you pull off the instrument panel cover, they are right behind where the glove box is. Edited December 3, 2025 by 55trucker Quote
pwmin Posted December 3, 2025 Author Report Posted December 3, 2025 2 hours ago, 55trucker said: Well, defrost is the default direction for all optional failures, as for the heat can you get your hands around the inlet or outlet core piping to feel what the coolant temp is? if the blend door is stuck closed so the inlet air bypasses the core that would deliver what you're presently getting. One can see the actuators if you pull off the instrument panel cover, they are right behind where the glove box is. Sweet, thanks. I'll pull the cover off and check and see if I can feel or laser temp the piping. Quote
55trucker Posted December 3, 2025 Report Posted December 3, 2025 You should be able to get at both sides of the heater core...return is at the front of the engine, that long steel piping that follows along the right side frame rail that sweeps upwards to the coolant pump manifold, the inlet side is right beside the brake vacuum booster, a short hose that passes overtop of the master cyl reservoir slipping over the steel supply pipe from the bottom of the thermostat housing. pwmin 1 Quote
ron350 Posted December 3, 2025 Report Posted December 3, 2025 (edited) Have you checked the vacuum line that supplys vacuum to the HVAC vacuum switch behind the glove box? On my 96 Regal acid from the battery ate the plastic vacuum line that runs under the battery tray to the vacuum ball. The vacuum ball is under the battery tray up inside the fender. The plastic line that connects the vacuum ball to the vacuum "T" breaks and this causes all HVAC air to blow out of the defrost vents. When this happened to me I replaced the brittle plastic vacuum line under the battery tray with rubber vacuum hose. Edited December 3, 2025 by ron350 Quote
pwmin Posted December 3, 2025 Author Report Posted December 3, 2025 17 minutes ago, ron350 said: Have you checked the vacuum line that supplys vacuum to the HVAC vacuum switch behind the glove box? On my 96 Regal acid from the battery ate the plastic vacuum line that runs under the battery tray to the vacuum ball. The vacuum ball is under the battery tray up inside the fender. The plastic line that connects the vacuum ball to the vacuum "T" breaks and this causes all HVAC air to blow out of the defrost vents. When this happened to me I replaced the brittle plastic vacuum line under the battery tray with rubber vacuum hose. I redid all the vacuum lines a little while ago because the turbo PCV wasn't set up properly. Maybe I messed something up. I think the vacuum ball is long gone due to packaging issues, but it was working at one time. Quote
ron350 Posted December 3, 2025 Report Posted December 3, 2025 (edited) That gear drive actuator you replaced controls hot to cold blend. There is a vacuum switch behind the glove box that sends vacuum to separate vacuum doors to control what vent the air comes from. That black plastic vacuum line that powers the vacuum doors goes through the fire wall between the master cylinder and the strut tower. This is what the vacuum door controller looks like. https://www.rockauto.com/en/moreinfo.php?pk=14268801&cc=1021374&pt=7036&jsn=531 Edited December 3, 2025 by ron350 pwmin 1 Quote
pwmin Posted December 4, 2025 Author Report Posted December 4, 2025 I haven't replaced anything yet. TBH, I don't have much motivation right now with it getting dark early and being cold. I'm hoping to look at it Sunday since I'll actually have a whole day to myself (I think) Quote
pwmin Posted December 9, 2025 Author Report Posted December 9, 2025 (edited) I checked it out and everything was working correctly as far as the blend doors goes. However, the inlet side of the heater core is cold, but the outlet side is hot? I'll check the coolant level. It's not overheating, but it gets warm. I wasn't getting any heat this time, but I do sometimes. Edited December 9, 2025 by pwmin Quote
pwmin Posted December 10, 2025 Author Report Posted December 10, 2025 The coolant was a little low, but didn't take much to top off the radiator. The overflow was almost completely empty, though. I did not run it again to see if that helped, so I'll do that later today, but I doubt it will help. Quote
Schurkey Posted December 12, 2025 Report Posted December 12, 2025 On 12/9/2025 at 5:54 PM, pwmin said: the inlet side of the heater core is cold, but the outlet side is hot? Question, or statement? Are you sure you have the correct flow-path through the heater core? You haven't reversed the inlet vs. outlet...right? Quote
pwmin Posted December 12, 2025 Author Report Posted December 12, 2025 4 hours ago, Schurkey said: Question, or statement? Are you sure you have the correct flow-path through the heater core? You haven't reversed the inlet vs. outlet...right? I wouldn't think so since I get heat sometimes. But, I did re-do the intake manifolds and went back to stock on the heater lines. I had ghetto tapped into the coolant lines for a turbo that I took out and went back to one without water cooling. I don't think I messed anything up, but it's definitely possible. Quote
Schurkey Posted December 12, 2025 Report Posted December 12, 2025 Point is, if the heater core is plugged with rust/scale/slime/garfelderfarb, the inlet should be hot, and the outlet cold. You're saying it's the other way around. Quote
pwmin Posted December 15, 2025 Author Report Posted December 15, 2025 On 12/12/2025 at 4:43 PM, Schurkey said: Point is, if the heater core is plugged with rust/scale/slime/garfelderfarb, the inlet should be hot, and the outlet cold. You're saying it's the other way around. Right. That's confusing; seems like it is routed incorrectly. Worked perfectly fine yesterday. Even more confusing. Quote
pwmin Posted December 17, 2025 Author Report Posted December 17, 2025 And it worked as designed yesterday... primergray 1 Quote
Schurkey Posted December 18, 2025 Report Posted December 18, 2025 (edited) Seems unlikely that it would air-lock and then work properly, then air-lock again. Same with plugging the coolant flow path--I can only think of one thing that would plug the heater core sometimes, and not other times. So I'm at a total loss as to why both heater hoses are not "hot" whenever the engine is fully-warm, unless you have a faulty heater-control valve, or heater valve control mechanism--dash controllers, faulty vacuum hoses, etc. Edited December 18, 2025 by Schurkey Quote
pwmin Posted December 18, 2025 Author Report Posted December 18, 2025 14 hours ago, Schurkey said: Seems unlikely that it would air-lock and then work properly, then air-lock again. Same with plugging the coolant flow path--I can only think of one thing that would plug the heater core sometimes, and not other times. So I'm at a total loss as to why both heater hoses are not "hot" whenever the engine is fully-warm, unless you have a faulty heater-control valve, or heater valve control mechanism--dash controllers, faulty vacuum hoses, etc. I will warm it up later today and check the temp of the tubes again. Quote
