carkhz316 Posted 5 hours ago Report Posted 5 hours ago As the title states, I'm looking for any/ all info in regards to the proper master cylinder needed for ABS deletion. I'm only wanting/ needing to do it in order to fit turbocharger piping in the engine bay, and not because of some naive safety circumvention. I am already running a smaller first gen brake booster found on the manual transmission cars if this matters. While searching RockAuto, there seems to be a lot of overlap between the 1st gen W-bodies through 1.5, with and without disc brakes, etc. So, I figured I'd ask the experts since I've seen brake systems discussed here in the past. Thanks! Quote
55trucker Posted 2 hours ago Report Posted 2 hours ago Being an ABS VI you will have to either re-bend the existing lines at the current ABS module to fit into the 4 ports of the non ABS master or add extensions onto what's there. What's not known is if what is there right now will have the same 4 different line nut fittings that the non ABS master makes use of. Each line nut that goes into the appropriate master port has a different thread pitch & diameter so they could not be mixed up. Quote
