carkhz316 Posted 4 hours ago Report Posted 4 hours ago As the title states, I'm looking for any/ all info in regards to the proper master cylinder needed for ABS deletion. I'm only wanting/ needing to do it in order to fit turbocharger piping in the engine bay, and not because of some naive safety circumvention. I am already running a smaller first gen brake booster found on the manual transmission cars if this matters. While searching RockAuto, there seems to be a lot of overlap between the 1st gen W-bodies through 1.5, with and without disc brakes, etc. So, I figured I'd ask the experts since I've seen brake systems discussed here in the past. Thanks! Quote
55trucker Posted 49 minutes ago Report Posted 49 minutes ago Being an ABS VI you will have to either re-bend the existing lines at the current ABS module to fit into the 4 ports of the non ABS master or add extensions onto what's there. What's not known is if what is there right now will have the same 4 different line nut fittings that the non ABS master makes use of. Each line nut that goes into the appropriate master port has a different thread pitch & diameter so they could not be mixed up. Quote
