2g Grand Prix dash removal?
Nothing wrong in bringing your lunch to a salvage yard, just hide the beer under the Mt. Dew.
Its not impossible but you do end up fighting a few different plastic clips while holding the dash with your knees at some point, IIRC. Just expect the upper sun soaked area to be brittle when you`re handling it so it doesn't crack. A factory service manual has very nice diagrams that show every mounting point.
It’s not impossible but you do end up fighting a few different plastic clips while holding the dash with your knees at some point, IIRC. Just expect the upper sun soaked area to be brittle when you`re handling it so it doesn't crack. A factory service manual has very nice diagrams that show every mounting point.
It’s at some guys house so if he’s cool enough he’ll supply the beer 😎
almost wondering if it’s more worth waiting for one to come up at an actual scrap yard and making a day out of it vs being at some random dudes house for 4 hours working on it..
I've never pulled the dash on my 2nd gen. The first gens are very easy. I can't imagine it's all that different. 2nd gen interiors are like legos.
Switching over to a ECC is probably more trouble than it's worth. Those units are known to have issues. Mine still works fine, but I like the simple controls of the manual climate controls.
Performance shift is cool and has been done many times. It's simple to do and you can get it tuned so it works properly.
  • Like 1
I did some searching. Looks like its pin 21.
My car only has the performance shift indicator on the DIC. I've thought about adding it to the gauge cluster.
I also want a real boost gauge and a gauge to monitor KR.
Edited by 94 olds vert
